Crash on opening file #42486
6 Participants
Reference: blender/blender#42486
Linux Ubuntu 14
nVidia GTX 560 ti
Broken: 2.70b
9e963ae
Worked: 2.71
With the supplied file I get an immediate crash once opening.
Open the attached file in blender (It has been created with version 2.71).
Added subscriber: @hilbert
File which crashes blender: Telefoon.blend
Added subscribers: @ideasman42, @JulianEisel
Hi @hilbert,
I can confirm the issue. You used an array and a mirror modifier with merging enabled in the file, right? The issue seems to lay somewhere there, but maybe the file is just corrupt.
@ideasman42, maybe you could have a look on this? I tried to provoke a crash like this, by playing with arrays and mirrors, without any "luck".
Added subscribers: @PatriceBertrand, @LukasTonne
The file crashes with an invalid read report from adress sanitizer:
https://developer.blender.org/diffusion/B/browse/master/source/blender/blenkernel/intern/cdderivedmesh.c$2970
The issue seems to be that
v_target
index is -1, which is generally allowed for the vtargetmap entries, but is not checked in this loop.DM_is_valid
does not complain, so i assume the mesh itself is not corrupted.@PatriceBertrand: Could you have a look at this? Thanks!
Adding @ideasman42
I will look at it.
The report says:
Broken: 2.70b
9e963ae
Worked: 2.71
Since modified array modifier was introduced in 2.72, I would assume this is not related to new implementation, right ?
Although indeed
is in new implementation. So maybe the "broken" indication is wrong ?
I think this is a typo, the commit link says 2.72b instead 2.70
The issue relates to array caps with merge option, caps having a subdivision surface active.
Easy to reproduce: start with default cube, duplicate cube as cube.001, define array modifier on Cube, set merge option, set Cube.001 as start cap / end cap.
Then add a subdivision surface on Cube.001 ==> crash.
For some - unknown at this point - reason, this condition causes the addition of a poly with totloops=0, which thus passes through the all_vertices_merged test:
A few lines further down, we are using the vertex of the first loop of the poly, while not handling the fact that mp->totloop can be null. A test could easily be added there, but that is not the correct solution.
I need to investigate further.
After further investigations, here's where I am:
The cap object's derived mesh is obtained by
Which returns a dm where, in the case of subsurf, polys are wrong. For example, the following snippet:
Will show inconsistent polys.
In my original patch, the cap object's dm was obtained by
Which, does not crash with the crash file, BUT does not apply the cap object's subsurf.
@ideasman42, maybe you know what is the appropriate way of getting the derived mesh with modifiers applied ?
Actually, even though previous versions of Blender did apply the cap object's subsurf if present, it is in most cases not what one would want. For example in the telephone.blend file, there is really no point in having a subsurf on the phone cord's caps BEFORE adding them to the cord. Not only does it give wrong results, but it actually prevents the merge from taking place, because after subsurf, the vertices do are not near enough to be merged. It would be better to add the caps THEN apply the cord's own subsurf.
This makes me think that applying subsurf to caps could be dropped altogether. But I suppose not everyone will agree.
Got it !
At
Should be :
Probably a typo.
This issue was referenced by
723f1e950b
Closed by commit
723f1e950b
.This issue was referenced by 2c1a386c9aeb717ddb1ac59536308b0f1374f443
