Knife Project bad precision #42864
Closed
opened 2014-12-10 13:01:48 +01:00 by Mikhail Rachinskiy · 17 comments
Windows 8.1 x64
Renderer: GeForce GTX 860M/PCIe/SSE2
Broken: 2.72.2 c8995ec
Knife Project tool gives unexpected results depending on zoom level and global objects position. Some artifacts could be evaded by moving objects slightly right or increasing/reducing zoom level, but if somehow I managed to escape one artifact, another pops out.
This tool would be very handy in product/jewelry design if it will be predictable and stable.
  • Open blend file project_knf.blend
  • See examples for unexpected results, and use test models for tests
Here is few screenshots:
**System Information** Windows 8.1 x64 Renderer: GeForce GTX 860M/PCIe/SSE2 **Blender Version** Broken: 2.72.2 c8995ec **Short description of error** Knife Project tool gives unexpected results depending on zoom level and global objects position. Some artifacts could be evaded by moving objects slightly right or increasing/reducing zoom level, but if somehow I managed to escape one artifact, another pops out. This tool would be very handy in product/jewelry design if it will be predictable and stable. **Exact steps for others to reproduce the error** - Open blend file [project_knf.blend](https://archive.blender.org/developer/F130581/project_knf.blend) - See examples for unexpected results, and use test models for tests Here is few screenshots: ![artfkt1.png](https://archive.blender.org/developer/F130584/artfkt1.png) ![artfkt2.png](https://archive.blender.org/developer/F130586/artfkt2.png) ![artfkt3.png](https://archive.blender.org/developer/F130588/artfkt3.png)
Author
Member
Author
Member
Added subscriber: @MikhailRachinskiy
Campbell Barton was assigned by Bastien Montagne 2014-12-11 09:53:40 +01:00
This issue was referenced by db0e2e7347
This issue was referenced by db0e2e7347db73786b38c0cbace60741ddd28b7e
This issue was referenced by 2329b58fd3
This issue was referenced by 2329b58fd3d978752d200952591fd4e7db7d0fca
Closed by commit 2329b58fd3.
Closed by commit db0e2e7347.
Changed status from 'Resolved' to: 'Open'
Thanks for the comprehensive report.
Fixed 2 of the issues:
  • missing cuts artfkt3.png (also around some of the other characters) 2329b58fd3
  • backface selection when cut-through is disabled db0e2e7347.
There is still an issue when cut-through is enabled. I think this is the issue you refer too artfkt1.png
Note that you can workaround this by rotating the model slightly, the issue seems to be caused by 2x intersections on different edges overlapping exactly.
Thanks for the comprehensive report. Fixed 2 of the issues: - missing cuts ![artfkt3.png](https://archive.blender.org/developer/F130588/artfkt3.png) (also around some of the other characters) 2329b58fd3 - backface selection when cut-through is disabled db0e2e7347. ---- > There is still an issue when cut-through is enabled. I think this is the issue you refer too ![artfkt1.png](https://archive.blender.org/developer/F130584/artfkt1.png) > Note that you can workaround this by rotating the model slightly, the issue seems to be caused by 2x intersections on different edges overlapping exactly.
This issue was referenced by 72341537e8
This issue was referenced by 72341537e872f2870e785d9fb8a24d2dbdd71471
Closed by commit 72341537e8.
Note, all of the reported issues are fixed now from what I can tell, it even fixes some issue you didn't report :)
Closed by commit 72341537e8. ---- Note, all of the reported issues are fixed now from what I can tell, it even fixes some issue you didn't report :)
Author
Member
Big thanks! Test cases are perfectly handled.
But I still get artifacts:
In this case it's selection and cut artifacts, very rare to catch, usually fixed by moving viewport.
To reproduce open blend file and press Knife Project.
This is selection only artifact, cut is alright.
To reproduce open blend file and shake the viewport a few times to get rid off previous artifact, and eventually you'll get this one.
The same as previous — selection only artifact.
To reproduce open blend file, and try test set to the left from current one.
Could this be a weak design of Knife Project tool? So it doesn't matter how much you try, there is always be a possibility for an artifact?
Big thanks! Test cases are perfectly handled. But I still get artifacts: In this case it's selection and cut artifacts, very rare to catch, usually fixed by moving viewport. To reproduce open blend file and press Knife Project. ![artfk_1.png](https://archive.blender.org/developer/F131957/artfk_1.png) This is selection only artifact, cut is alright. To reproduce open blend file and shake the viewport a few times to get rid off previous artifact, and eventually you'll get this one. ![artfk_2.png](https://archive.blender.org/developer/F131961/artfk_2.png) The same as previous — selection only artifact. To reproduce open blend file, and try test set to the left from current one. ![artfk_3.png](https://archive.blender.org/developer/F131966/artfk_3.png) Could this be a weak design of Knife Project tool? So it doesn't matter how much you try, there is always be a possibility for an artifact?
Author
Member
Test file [project_knf_2.blend](https://archive.blender.org/developer/F131971/project_knf_2.blend)
@MikhailRachinskiy, project_knf_2.blend is really related to #42459, so leaving this report closed & linked to the test-cast from there.
That cutting at large or small scale will give problems. Its a real bug but unrelated to the other problems.
Id rather leave this for after 2.73 release.
@MikhailRachinskiy, `project_knf_2.blend` is really related to #42459, so leaving this report closed & linked to the test-cast from there. That cutting at large or small scale will give problems. Its a real bug but unrelated to the other problems. Id rather leave this for after 2.73 release.
Author
Member
OK, thanks!
OK, thanks!
Reference: blender/blender#42864
