Collada export -> import materials don't work #43366
7 Participants
Reference: blender/blender#43366
Windows 7 64bits
Blender 2.73a
If I export a mesh with collada and import to blender the material and textures don't work and only import the specular texture. I have tried differents options to import/export, with lambert specular 0,...
error.zip
Added subscriber: @AlbertoVelazquez
Added subscribers: @mont29, @JulianEisel
Works fine here. And again, I'd blame your graphics card (See your other reports).
@mont29 any reason why using BF Blender or was that done by accident?
@JulianEisel Collada is BF-Blender (core C/C++ code), not addon! ;)
I will try to explain a few more the bug.
If you see the collada file you will see the problem exporting the file. For some reason the collada don't write properly the texture. In the example if I import the collada I obtain one box with one material with two textures with the same image file (spec.png). Instead of three textures (normal, difuse and spec)
This happens with a hundred of files of our proyect.
Added subscriber: @SaurabhWankhade
If in Normal texture Influence->Geometry->Normal is checked, the texture would be exported propertly,but will fail to import back properly.
so if you have any normal texture drag it down to the bottom, because while importing back it would stop importing from the point where normal map texture is encountered.
say the texture are in the order.
Then the ones that will be imported back will consist only of
Textures after Normal and ambient wont import back in.
I will try to fix the Import Normal texture after later.
Added subscriber: @RobertBaer
Windows 8.1 Blender 2.73 Collada Export/Import - Round trip
Steps to reprooduce
Load blend file with an image texture material
or an image texture material with also a normal map
Verify that the round trip is successful if the objects are exported/imported as .obj
Related:
Import a .dae file created elsewhere (MakeHuman in my case) that has both a texture and a normal mapped material. Note that the texture map imports, but not the normal map. There also seem to be import errors related to the handling of transparency.
If any or all of this is a separate issue I can make a separate bug report.
So what's the status here? @SaurabhWankhade, any luck so far?
@JulianEisel D1028 fixes wrong(spec color -> diff) mappping, need some one to verify, test and commit it.
@RobertBaer Transparency issue : already mentioned here #27161. Transparency value is exported to the collada file, but in the collada libs there is no way to access transparency(unless there is a workaround).. so it can be fixed only when libs are fixed.(See COLLADAFWEffectCommon.h, there is api for getting value from collada file like getShininess () etc., but not for transparency.. for some reason parts of code are commented out i.e. mTransparency, mTransparent)
Attaching test files..
file.tar.gz
I have tested the test files with the actual version, 2.73a, and the last in the builder blender-2.73-1dddcfb-OSX-10.6-x86_64.zip. And in all the version I only obtain two textures, not three.
patched_normal_at_bottom > Normal map and Spec (in this order) with the normal map like a diffuse map
patched_normal_at_bottom_with_normal_enabled > Diffuse map and Spec
patched_original > Diffuse map and Spec
unpatched_normal_at_bottom > Normal map and Spec (in this order) with the normal map like a diffuse map
unpatched_normal_at_bottom_with_normal_enabled > Spec and spec, the first spec like a diffuse map
unpatched_original > Spec and spec, the first spec like a diffuse map
in other way, now OSX can read the diffuse texture in the preview of the file system in the patched versions, at least the diffuse.
@AlbertoVelazquez : the patch is not yet commited, so it wont show up in the nightly build. :)
patched_normal_at_bottom -> The name "normal map" has color enabled(and not the normal mapping), so it is exported as diffuse texture.
patched_normal_at_bottom_with_normal_enabled -> "normal map" wont load, bug.
@SaurabhWankhade I suppose that, anyway I want test it and tell the results if this wasn't be the case.
This issue was referenced by
a78a17bad5
Closed by commit
a78a17bad5
.thanks to sauraedron (Saurabh Wankhade) for this patch :)
