OpenGL Driver losing connection with display using certain volumetric shader node configurations #43496
Reference: blender/blender#43496
System info: system-info.txt
When using the 'Tangent' On geometry connected to the color input of a volumetric shader (Node setup), it crashes the OpenGL driver.
Both monitors rebooted, and the display driver notified me that it had in fact rebooted.
Node Setup:
Geometry: Volume Absorbtion:
.Blend file and screenshot of the message given by my display driver:
Crash.blend
Added subscriber: @Masterchef365
Please never attach system info as an inlined text since it makes report almost unreadable. Attach as the file instead.
The setup might be not totally trivial for GPU, so if you're not having dedicated GPU for rendering (and separate for the display) you'll run into time limit sooner or later. This is just how CUDA works. What's worse, that's also what windows restricts even further..
But i can see crash when rendering with CPU, so there is at least something to be looked into. Will investigate.
Ok, had a closer look. You can't actually use tangent for the volume. Tangent is a surface property, not defined for the volume.
Will commit fix for the crash (and hopefully for the driver timeout) now, but the setup wouldn't give what you're expecting from it perhaps.
This issue was referenced by
03cb146afa
Closed by commit
03cb146afa
.This issue was referenced by blender/cycles@4625d070bb
