Wrong creation in rotated curve objects #43498
5 Participants
Reference: blender/blender#43498
Windows 7 64, GTX 980
Broken:
bbf09d9
+3f57714
(I think this has never worked)
The radius setting in a curves Editmode doesnt work correct if the curve object is rotated.
Very simple:
Added subscriber: @karja
You need to apply the rotation first (Object mode -> Ctrl+A). Please add a comment if this still doesn't give you the desired behaviour. We can then consider reopening.
But thanks for the report :)
I think you misunderstand me. Applying works, but isnt a solution where the curve object should keep the object mode rotation. For example to trick the twisting.
This curve object is rotated X 90° (object mode) - shown by the big circle.
By adding additional curves in Editmode they get automatically rotated for global space, which is no problem.
The problem with new curves in Editmode seem that local Z-Axis Scale is ignored or not taken into account when changing "Add Nurbs Circle - Radius".
It only affects local X Y Axis of the object and that results in a pressed circle.
Keep in mind that new creations first use the Grid Floor Scale or the last radius you have set it up to determine the circles radius. Lets say I have it at 0,05 - then this is the curve I will start with:
Added subscriber: @zeauro
I still don't think we have a bug here, it's more like you want it to work this way, but essentially everything works fine. I'd like to get input from a more advanced user than me though ;D @zeauro, does this look like a actual bug for you? Or do you have a workaround or such?
The workaround is to use scale operator of edit mode instead of this setting.
It is probably what are doing most of users that did not notice the problem.
But obviously, the setting does not work as it should, as expected when you have already use it in edit mode for meshes.
I mean what is expected is a scale of primitive that preserves its shape.
May i ask to reopen this case?
Workaround is easy and not really a problem, only sort of annoying. But as zeauro pointed out, this is not consistent to mesh setting.
Compare this to a Plane mesh - its flat and Z could be ignored for the radius setting but works fine in any rotation.
Added subscriber: @ideasman42
Oki, will reopen for now, but would like to get @ideasman42's input
This issue was referenced by
c4e8d74563
Closed by commit
c4e8d74563
