Changing vertex position creates permanent lag in rasterizer and cpu. #43761
5 Participants
Reference: blender/blender#43761
Win 7 64 bit , Geforce 730m i5 3230m
Broken: 2.71
When setting the coordinate of (even) a single vertex (vertex.setXYZ) the rasterizer goes crazy.
http://blenderartists.org/forum/showthread.php?362541-Vertex-manipulation-and-rasterizer-issue
""" I confirmed that it is the display lists being rebuilt every frame that causes the problem.
If you disable Display Lists under Properties -> Render -> System,
the performance becomes the same as if you had already moved a vertex and does not change when you do.""" - qoute from Mobius
The size of the mesh increases the performance hit so this can be seen better on huge meshes that otherwise run fine in game.
Here is the gif where you can see it before and after changing one vertex position.
hacks that work
changng the vertex during the code run/(logic tic) when the object was added (addObject)
what i would like
""I don't know much about display lists or even if patching the BGE so it only rebuilds the display list once would be a performance improvement over calling replaceMesh.""" - Also from Mobious
Maybe that.
blend
vertexAccesProblem_(1).blend
Added subscriber: @vegetablejuicef
Added subscriber: @MikeErwin
Added subscriber: @panzergame
Hi vegetablejuicef, it seems that your mesh is enormous, if you make parts of your mesh and modify it differently it can be better.
Hi, sorry for the late response.
Surely, that is possible and advised, but that should not excuse the issue at hand.
The thing is( or was) that I had a energy beam that blasted through the whole map:
Either i edit 1 big mesh and get a huge lag.
Edit 4 medium meshes and get 4 medium lag spikes = huge lag.
Or I edit 10 smaller chunks which causes 10 * ( lag / 10 ) = still the same.
You get it by now I hope.
Of course, as the "fix" for this can be applied to the smaller meshes over several frames,
but then instead of being short and painful, it will be unresponsive visually and still lag.
The size of the mesh is not important, the sizehere was just toillustrate the problem.
It was made so that my old HD5770 could choke a little.
So yeah, I can try to shove the problem under a carpet or at least ask for it to be looked at here.
Added subscriber: @AngusHollands-4
This has been noticed before, we should look at this at some point (i.e, not low)
This issue was referenced by
3b359f1fea
Closed by commit
3b359f1fea
