Adding a constraint to a bone of a proxy armature resets all bones' transformations. #43872
Reference: blender/blender#43872
W8.1 64b, GF 250
Blender 2.73a
ref.blend
scene.blend
Maybe it is limitation, it is not serious, keyframe are ok, but it reset all if you dont have keyframe.
Added subscriber: @Cenda
Constrain is reseting linked positionto Adding a constraint to a bone of a proxy armature resets all bones' transformations.Added subscribers: @JoshuaLeung, @ideasman42, @Sergey, @mont29
Issue here is adding a constraint to a bone of a proxy armature (any constraint does the same).
Not even sure this should be allowed?
OK, so in your ref.blend file, all bones of the armature are in a protected layer. This implies you should not be able to edit them (like adding a constraint).
Grmlll… And yet, code explicitly allows adding constraints to locked bones… Have to dig this more.
@mont29: I think animators would beg to differ - Being able to do that is pretty much essential to being able to add constraints for grabbing/hanging on to props.
@JoshuaLeung yep, realize that.
In fact, I think it boils down to an update issue (i.e., the fact that transformation is reset is expected behavior, but animation should be immediately re-evaluated then):
BKE_pose_rebuild()
).What I do not know is how to force re-evaluation of animation afterwards - I tried to tag update
OB_RECALC_ALL
(which includes time) in this case, but no luck so far. :/If you only want to force animation refresh, you can simply tag the relevant animdata->recalc with ADT_RECALC_ANIM and it will do that
I also found in manual that I can not add constraint to Protected Layer, so I was surprised that I can :) But it is good for props. Also it will be fine if my pose will not reseted after added constraint, if I dont have keyframe yet.
@Cenda: you should always key your transforms on locked proxy bones, many things in Blender will reset them to lib position otherwise (like undo/redo, etc.). This is not a bug, if you want complete freedom for your proxy bones then place them on a non-locked bone layer in your lib file.
This issue was referenced by
b21e0cccfa
Closed by commit
b21e0cccfa
