Quick Fur duplicate particle system on edit #43887
5 Participants
Reference: blender/blender#43887
Windows 7
Nvidia GTX 660
Broken: 2.73
Every time you edit the values in the quick fur properties window, you will create a duplicate particle system, each time you change a value
The bug only happens when you change the properties in a quick fur that is added in edit mode, otherwise it will work as intended.
Attached video shows how to reproduce the error
Particle system duplicate - video link (dropbox)
Particle_systemduplicate.mp4 - video download
Added subscriber: @UnknownFreak
Added subscribers: @LukasTonne, @ideasman42, @JulianEisel
Can confirm that. Add quick fur in Edit Mode -> change settings in redo panel -> A new particle system is added.
Not sure what triggers this, but I'd say it's the undo system. Disabling the rna prop update call doesn't work. @ideasman42, @LukasTonne any ideas?
Downloaded and played with the new testbuild, problem still presisted, so I decided to look up the "quicktools" file (object_quick_effects.py)
and took a look in there, tested some different things, and decided with a friend. For now, the best solution
is to add:
in the class QuickFur(Operator):
This will force the user into object mode (where the bug cannot happen).
There is probably a better solution. But it will do for now.
Added subscriber: @Sergey
The issue is caused by edit mode using local undo stack, which doesn't store particle system settings. But i don't think changing object mode is the proper way to go, imo it's better to just forbid adding fur onto objects which are in edit mode: http://www.pasteall.org/57142/diff
P.S. Ic sohuld probably check object's mode is OBJECT, so there's no issues with quick fur called for objects which are in paint/sculpt modes.
Agree - best just disable this in editmode.
This issue was referenced by
51a60cbaf8
Closed by commit
51a60cbaf8
