bpy.ops.file.unpack_all() for packed entities without filename #43910
Reference: blender/blender#43910
Applies to all operating systems
Broken: 2.73
If a packed image has an incorrect filename - for instance one that ends with a slash (like "//..............") - then unpacking fails with an exception.
If a packed image resource simply has no filename then it cannot unpack either. No error is thrown but a message is shown in the console and the file remains packed.
The attached .blend contains an object with a packed texture. Press Alt+P (run script) in the text view to call unpack_all() or select unpack->write_local from the file menu.
The error message will show once the console is opened:
Similarly for a resource with an empty filename:invalid_unpack.blend
Suggested behaviour
In the case where the resource is otherwise valid, an appropriate unique name can be generated for it upon unpacking it. For example a PNG image without (proper) filename could be unpacked as "F3N8SKA929_AUTOUNPACK.PNG".
This would allow external/internal tools to properly access the resource - for instance to render the .blend file with a renderer that can only load files from the filesystem and not directly from the packed .blend-file.
Added subscriber: @JanusBagerKristensen
The .blend-file link accidentally ended up somewhere in the middle of the bugreport and I can't edit it - here it is again:
Will tackle that.
This issue was referenced by
8dbbb60e8a
Closed by commit
8dbbb60e8a
.Added subscriber: @Harry-Kunz
is it possible to loop through the unpacked files and rename them before unpacking? because unpacking files with names image.png.001, image.png.002, image.png.003, results in only 1 file overwriting all with final name image.png
