VSE Mask Modifier don't move with video-Clip #43986
5 Participants
Reference: blender/blender#43986
Windows 8.1, AMD Radeon R9 200 Series
Broken: 2.73a
bbf09d9
When I use the Strip Modifier --> Mask and put a animated mask, I created before in the movie clip editor, to the clip I want to mask out, then the mask is not in sync with the Clip. If I move the Clip at the Timeline, the mask animation is still at the same frames on the Timelin, it was before I moved the movie-clip.
If you placed your Clip at Frame 0 (not 1!), The mask is in synk with the clip, if you place the clip anyware else, mask and clip are out of sync.
"Refresh Sequencer" and reloading the mask will not work. Before I reported this bug, I tried it 3 times in different projects.
Added subscriber: @dennisschiffer58
Uh, actually, I hit the same issue a few days ago… Will try to find some time to investigate, probably not that complicated (though you never know with VSE).
This issue was referenced by
6786ef6783
Closed by commit
6786ef6783
.Added subscriber: @DanteLeoncini
Changed status from 'Resolved' to: 'Open'
tested on ubuntu 18.04 64bits
Good, This error is still in blender 2.79 as in blender 2.8.
I have been using masks in blender for a long time and this problem always existed.
At first I thought it was a problem with the mp4. But this happens in sequences of png and exr images as well.
The mask looks bad in both the "Movie Clip Editor" and in the render of the Composition, when moving a vertex of the mask and pressing the escape key, the mask is displayed correctly. This makes it very difficult to find errors, because when looking at the "movie clip editor" it seems that the mask is always wrong, when reality is right. The only way to see the final result is to render or move frame by frame and move the vertices to see if that frame is fine.
Now I'm trying to finish a sequence of 746 frames. Because of this problem I had to create a keyframe in all the boxes to be sure that the cut is perfect, which took me several days. If this error did not exist it would have been easy to see which frames did not lack any keyframes and save a lot of work
Mensaje original:
probado en ubuntu 18.04 64bits
Buenas, Este error sigue estando tanto en blender 2.79 como en blender 2.8.
hace mucho que uso las máscaras en blender y este problema siempre existió.
Al principio pensé que era un problema con los mp4. Pero esto ocurre en secuencias de imágenes png y exr también.
La máscara se ve mal tanto en el "Movie Clip Editor" como en el render de la Composición, al mover un vértice de la máscara y presionar la tecla escape, la mascara se muestra correctamente. Esto hace muy dificil encontrar errores, ya que al ver el "movie clip editor" parece que la mascara esta siempre mal, cuando enrealidad esta bien. La unica forma de ver el resultado final es hacer un render o moverse cuadro por cuadro e ir moviendo los vértices para ver si ese fotograma esta bien.
Ahora estoy tratando de terminar una secuencia de 746 fotogramas. por culpa de este problema tuve que crear un keyframe en todos los cuadros para estar seguro de que el recorte sea perfecto, lo que me tomó varios días. Si este error no existiera habría sido fácil ver en cuales fotogramas no hacia falta ningun keyframe y ahorrar mucho trabajo
Added subscriber: @brecht
Please don't open 4 year old reports like this, but create a new one.
https://developer.blender.org/maniphest/task/edit/form/1/
