OpenGL memory leaks when using Save User Settings. #44025
5 Participants
Reference: blender/blender#44025
OSX 10.9.5, i5, 16GB-Radeon 6670m
Hash:
4aa5109
Not sure how far back this goes.
User Preferences-> Save User Settings shows memory leaks when profiling with Apple's Instruments->Leaks
I've attached some screen-captures that show the results. They are a bit inconsistent. Sometimes 3 functions show up in the report and sometimes it's only one or two of them.
This does not appear to be scene specific. There was nothing in the scene but a few lights on a hidden layer and one cube on the active layer.
I tried it several times to see if can be reproduced and at least one of the errors is showing up every time.
I also tried resetting to factory defaults, which I did twice since this has been necessary for about a year now(at least on OSX) and several several malloc and calloc errors showed up from that. The Save User Settings errors still showed up when I tried them again.
Also, ;) drag and drop is leaking. It happens for both .blend files and image files.
(In the following image there are also 3 calloc errors but I was not paying attention to the profiler when they happened so I'm not sure what set that off. )
Usually it's only the handleDraggingEvent that shows up for that problem.
Added subscriber: @MarcClintDion
Added subscriber: @Sergey
First of all, it's not really clear what are the steps to reproduce the leak. This is important to provide exact steps and sample .blend file where the issue happens 100% of cases.
Further, blender does use own guarded allocator and some of the errors reported by the tool you're using are coming from it (all those MEM_lockfree_malloc and similar functions). If the leak indeed happens, then you can run blender from the console with --debug-memory argument and on exit blender will print all non-freed datablocks. Having that list would help finding actual leaks.
Can't say anything about drag-n-drop, since don't have mach handy to test it.
P.S. Title is also seems to be misleading -- it mentions OpenGL memory, but the reports is about CPU memory by the looks of it?
It's the NSOpenGLPixelFormat GHOST_ContextCGL::initializeDrawingContext() that made me think that there is something going on here with OpenGL. That one keeps coming up randomly.
(i)After using ./blender --debug-memory: Open a blank scene-> 1st use Ctrl+u to save the default scene, then activate User Preferences-> Save User Settings. It only happens consistently for me when I save both the Defaults and User Settings one after the other.
For this first one, nothing is showing up in the Terminal, the leak is only showing up when I use -> Apple Dev tool: Instruments->Leaks
The screenshot shows the following functions and one of them appears to be OpenGL initialization.
(ii)After using ./blender --debug-memory: -> when opening any .blend file(With Load UI activated!, the following does not happen when Load UI is deactivated)
Error: Not freed memory blocks: 4, total unfreed memory 0.000801 MB
IDProperty len: 128 0x1121947e8
IDProperty group len: 128 0x112572a98
IDProperty string len: 128 0x112572b58
id property string 2 len: 36 0x1121948a8
(iii) After using ./blender --debug-memory: Drag and drop an image from the HD into the node Editor, Blender reports the following to the terminal.
IDProperty len: 128 0x111838c18
IDProperty group len: 128 0x111e174b8
IDProperty string len: 128 0x111e17578
id property string 2 len: 36 0x111838cd8
Next is what happens when I activate Load Factory Settings but still have the User Settings enabled so the Addons I had enabled do seem to be a factor here. When I clear out everything Blender reports no errors but with Custom Users settings(and using Default Scene/Cube) the following is reported by Blender. Here are the .blend files for startup and userpref, not sure that will be very useful since the scripts themselves are too big to load here. I'll find a way if you want them.
IDProperty len: 128 0x1119af828
IDProperty group len: 128 0x1119af8e8
IDProperty string len: 128 0x111c8ea88
id property string 2 len: 36 0x111c8eb48
IDProperty len: 128 0x114a98048
IDProperty group len: 128 0x114a98108
IDProperty string len: 128 0x114a981c8
id property string 2 len: 36 0x114a98288
With both Start up and User Preferences set to defaults, there seems to be no issues reported by Blender however,
Apple's "Instruments->Leaks" is still picking up the Save Startup/Save Prefs Combo. And the drag and drop(which looks even worse now.)
I'm too confused to take this any farther right now...
OpenGL memory and memory used by opengl initialization are totally different things.
Do you have memory leaks reported when you're using
blender --debug-memory --factory-startup
?Added subscriber: @jensverwiebe
./blender --debug-memory --factory-startup was used and I deleted Library->Application Support -> blender -> 2.74 entirely just to be sure.
Everything is coming out clean with this.
"xCode->Instruments->Leaks" is reporting:
handleDraggingEvent(,,,) is leaking 16 Bytes
and for the SaveNSave combo it's reporting
initializingDrawingContext(,,,) is leaking 96 Bytes.
WindowCocoa(,,,) is leaking 64 Bytes
"xCode->Instruments->Leaks" no longer reports an issue with loading any non-specific .blend files using 'Ctrl+o'
Now I suppose I should start enabling all the Addons a few at a time and then running each of the 3 tests again to see what is causing Blender to spill it guts.
I did try to trip up xCode's Instruments Leak tool by repeatedly pressing the "Snapshot Now" button while it was already busy and I also tried causing it grief by performing various actions using Blender while "Leaks" was accessing Blender and it did not trip from this.
I do not know this tool well enough to say much about its accuracy or reliability, although the GPU analyzer component has proven effective a finding even the smallest OpenGL buffer mis-allocations for me.
Maybe @jensverwiebe would like to fire up some of his tools since a lot of this is being triggered around OSX API doo-hickies.
Saving defaults is not required to reproduce the OpenGL errors.
While running another profiling tool(Instruments->Counters->Sample List), I was able to get glewContextInit to show up in the running list every time I opened the User Preferences dialogue.
It looks like a second thread is being called to do this, I guess that's normal for a second window...
Added subscriber: @Psy-Fi
OpenGL issues i don't see on linux, must be something platform-specific. @Psy-Fi, mind checking those on the mac in the studio?
Other issues seems are coming from your custom startup file. Without that file it is unlikely we can reproduce the issue. It might also help if you isolate what exact setting/addon is causing the issues.
I'm not able to reproduce those unsightly error dumps from Blender even when I move the 2.73 config files back into 2.74 which is pretty much what I did a week ago.
Today, now that I have restored Blender back to mostly how it was all week and using --debug-memory, mostly looks fine. I didn't reboot, not sure what changed here.
Here are some links for setting up and accessing some of Apple's profiler tools
http://www.raywenderlich.com/23037/how-to-use-instruments-in-xcode
https://developer.apple.com/library/mac/documentation/DeveloperTools/Conceptual/InstrumentsUserGuide/InstrumentsQuickStart/InstrumentsQuickStart.html
Apple's "OpenCL_NBody_Simulation_Example" is the closest to being like Blender when it comes to it's OpenGL setup.
https://developer.apple.com/library/mac/samplecode/OpenCL_NBody_Simulation_Example/Introduction/Intro.html
I would avoid the official openGL stuff. It all seems to be designed to force a core profile.(annoying). (4.1+ wouldn't be so bad. It includes 2.0 ES spec)
@jensverwiebe @dfelinto both use OSX I believe.
It looks like this is being called for sub-window creation but not deallocated afterwards. It seems to have undergone substantial change since 2.72
"Duplicating Area Into New Window" has the same effect as the "User Preferences" pane after being opened and closed again.
Assigning to @Psy-Fi so he has the duty to check ;)
On this and already found something:
Nor yet sure what i need todo here ....
Btw: you better find it with analyse.
Jens
This issue was referenced by
0582aa6f13
Closed by commit
0582aa6f13
.I commited a fix for issue documented above ( 1 left refCount ), but there is more.
Oddly if i test in xcode with "Guard Malloc", there is nothing shown and also Instruments/Leaks does not show the leak anymore.
Jens
ff455f1ae1
