array modifier "fit curve" mode not working properly #44361
5 Participants
Reference: blender/blender#44361
all
Broken: 2.74
The full length of the curve is not used by the array modifier, the 2 last copies are missing
Open attached file, above is the buggy "fit curve" version, under it the "fixed count" version, using the full length
test_curve_and_array.blend
Added subscriber: @bliblubli
Added subscriber: @mont29
Yep, there is an error in how number of object is computed from curve length (missing a
+ 1
). Note your curve is slightly too short though, you need to add a tiny bit of length to it to get the other 'missing' copy.This issue was referenced by
4fb33d82e2
Closed by commit
4fb33d82e2
.thanks for the fix :)
Added subscriber: @wigarsu
Actually I believe this is notthe correct behaviour - it was correct before the fix!
The manual says "Generates enough copies to fit within the length of the curve object specified in Curve."
I suppose it can be argued whether on a line of length n you can fit n or n+1 objectcs of size 1.
According to bliblu bli's version it would be n + 1, with the first and last object sticking out by one half unit over the ends of the curve - but then the total size of these objects would be one unit more than the length of the curve.
Also, the extra object causes problems if you close the curve, or join several of such curves into a chain.
Finally, one application of the array modifier together with the curve modifier would be to place objects along the segmentsof a polygon - but then a polygon with n vertices has only n-1 segments.
Changed status from 'Resolved' to: 'Open'
In addition to my above comment, I would think that the endcap feature is meant to solve bliblu bli's problem. (at least for one of the two missing cubes - the other one is correctly taken into account by adding the epsilon in the fix).
In MOD_array.c, the line
count = (length + eps) / dist + 1;
should be
count = (length + eps) / dist;
Added subscriber: @Blendify
@mont29 can you take a look at the fix?
We can always argure on how fit to curev behaves, but this has nothing to do in this bug report. Should be handled through ML, get stakeholders artists on board to discuss what they want as behavior - keeping into mind that unless there is a really good reason for it, we'd rather not change behavior of working code, this would be really bad when opening older files.
This should never have been re-opened that way, bug tracker is to handle bug, not design tasks or feature requests.
