freestyle crashes blender #44404
7 Participants
Reference: blender/blender#44404
OS: windows 8 64bit
GPU: nvidia gtx 860m
Broken: official 2.74
when rendering a animation with freestyle and "line set" options enabled blender crashes
1.open the blend file test01.blend
2. make sure freestyle is enabled
3. render the animation a couple of times (till blender crashes)
there are also a couple of error messages when rendering when all "selection by" are disabled:
note that when these are disabled blender does not crash so i guess the crash is somehow caused by these options
Added subscriber: @DanielGrauer
Added subscriber: @mont29
Main issue (crash with weird BT) is not specific to Freestyle, we have other similar reports, will merge this one in it.
Closed as duplicate of #44238
Added subscriber: @Psy-Fi
I don't think merging is the correct thing to do, the backtrace does not work on release builds, and will display the exact same thing almost everywhere, regardless of the crash.
Changed status from 'Duplicate' to: 'Open'
Added subscriber: @kjym3
Many thanks @Psy-Fi for the notes on incorrect backtrace on release builds. I guess I was one of many who got confused by a backtrace that apparently makes no sense. I could reproduce the reported bug by a RelWithDebInfo build within VS 2013 (the bug was not reproducible in a Debug build). Here is a backtrace from the debugger.
I still need to further investigate the cause of bug. There is something wrong in the layer of the Python API, but debug symbols are not available in the backtrace above, which makes it difficult to identify the reason of the crash.
Anyway I will reopen the issue as confirmed.
Added subscriber: @Sergey
Added subscriber: @ideasman42
Looks like this is caused by freeing compiled Python objects in a thread.
Suggest not to use
Text
data at all. Just allocate a buffer and callBPY_string_exec
instead.Wow thanks Campbell for the advice. I will try the suggested fix asap.
This issue was referenced by
85ae4b87af
Closed by commit
85ae4b87af
.was this fix done in a branch? i still get the crash with the latest build but now the crashlog contains no more information except this
im building now a debug version and hopefully get more information about the crash, but im not a coder so i might need some help to do so.
EDIT: looks like its comming from a contrib addon "render_auto_save.py"
but i got a crashlog from a debug build so maybe that points to other problem
@DanielGrauer, it is likely to be a race condition between threads, so ideally we need to have backtrace of all threads. Any chance you can get those from IDE?
Also, did i understand correct that disabling autosave addon solves the crashes?
@Sergey, can you tell me what i need to do to get the backtrace from IDE?
and yes if i disable the austosave then i can not get it to crash (at least in the ~30-40 times i tried)
@DanielGrauer, not from a top of my head. Would probably be simplier to me to compile debug build and try to reproduce it first.
Also, it seems to be separate issue, so do you mind firing a new bug report and assigning to me?
