Blender Shuts Down when importing a .dae (Collada) file #44648
Closed
opened 2015-05-09 22:56:44 +02:00 by Kaleb Provost · 20 comments
Windows 8.1 Pro N
ATI Radeon 3100 Graphics (OpenGL 3.3, DirectX 11)
Broken: 2.74
Whenever I try to import a .dae file, Blender stops responding then shuts down.
{F171968}zStgBattleFieldStage.dae
  1. I tried to import a .dae file (StgFinal00stage.dae) through the import section in the file button.
  2. When I pressed import, Blender stopped responding and shut down.
  3. I tried another .dae file (zStgBattleFieldStage.dae) and it still didn't import the file.
  4. I opened Blender with the Command Prompt and I found some interesting output (posted here ).
  5. The output said that it generated a .txt file named blender.crash.txt (which I posted here ).
**System Information** Windows 8.1 Pro N ATI Radeon 3100 Graphics (OpenGL 3.3, DirectX 11) **Blender Version** Broken: 2.74 Whenever I try to import a .dae file, Blender stops responding then shuts down. **Exact steps for others to reproduce the error** {[F171968](https://archive.blender.org/developer/F171968/StgFinal00stage.dae)}[zStgBattleFieldStage.dae](https://archive.blender.org/developer/F171970/zStgBattleFieldStage.dae) 1. I tried to import a .dae file (StgFinal00stage.dae) through the import section in the file button. 2. When I pressed import, Blender stopped responding and shut down. 3. I tried another .dae file (zStgBattleFieldStage.dae) and it still didn't import the file. 4. I opened Blender with the Command Prompt and I found some interesting output (posted [here ](http://pastebin.com/8YSPhP8z)). 5. The output said that it generated a .txt file named blender.crash.txt (which I posted [here ](http://pastebin.com/CxR8H56p)).
Author
Kaleb Provost self-assigned this 2015-05-09 22:56:44 +02:00
Author
Added subscriber: @kprovost7314
Kaleb Provost was unassigned by Aaron Carlisle 2015-05-09 23:39:36 +02:00
Member
Added subscriber: @Blendify
Gaia Clary was assigned by Bastien Montagne 2015-05-10 08:47:09 +02:00
Added subscriber: @mont29
Crash confirmed, Gaia, think this one is for you. :)
.dae file seems invalid, but should not crash anyway…
Crash confirmed, Gaia, think this one is for you. :) .dae file seems invalid, but should not crash anyway…
This issue was referenced by 0525db39d1
This issue was referenced by 0525db39d13fbcbf078b8297fbe54387da49a371
Member
Member
Closed by commit 0525db39d1.
Author
This comment was removed by @kprovost7314
*This comment was removed by @kprovost7314*
Member
@kprovost7314: Have you been able to verify that the fix works for you?
Author
Member
this one: commit 0525db39d1 This commit should be available since a couple of days in the daily blender builds.
Author
Added subscriber: @sindra1961
@kprovost7314:
You should confirm whether you download the daily build version that it was revised, and it was improved.
Download Latest Builds
@kprovost7314: You should confirm whether you download the daily build version that it was revised, and it was improved. [Download Latest Builds ](https://builder.blender.org/download/)
Author
Added subscriber: @GaiaClary
Author
Author
Member
Yes, the commit will be included in Blender 2.75
i also have tested both files again and they import without crashing blender. However they both report errors on the console. One of the errors looks like a missing feature in the Opencollada libraries. In more detail the opencollada validator reports back:
  Schema validation error: Error: ERROR_TEXTDATA_PARSING_FAILED Element: minfilter, Line: 834, Column: 50, Additional: ¶
and blender can not do much more than reporting this. I took a brief look at the Collada specifications and actually there is no obvious error in the reported line. Also the reported error does not seem to be correct (there is no additional line break in the data). I will talk to the OpenCollada people to decide how we should handle this issue.
However both files can be imported by Blender.
I can not confirm that blender hangs during close. Maybe this happened to you because you have marked a line in the console? In that case the console only closes after the mark has been released (very annoying, but it looks like this is Windows behavior and not related to Blender)
As a sidenote: I wonder if the scaling in the collada files is correct. I found:
  <asset>
      <contributor>
          <authoring_tool>BrawlBox</authoring_tool>
      </contributor>
      <created>2013-11-26T00:40:30Z</created>
      <modified>2013-11-26T00:40:30Z</modified>
      <unit meter="0.01" name="centimeter" />
      <up_axis>Y_UP</up_axis>
  </asset>
It looks to me like the unit should be:
        <unit meter="1.0" name="meter" />
At least it makes more sense when looking at the geometry data.
Yes, the commit will be included in Blender 2.75 i also have tested both files again and they import without crashing blender. However they both report errors on the console. One of the errors looks like a missing feature in the Opencollada libraries. In more detail the opencollada validator reports back: ``` Schema validation error: Error: ERROR_TEXTDATA_PARSING_FAILED Element: minfilter, Line: 834, Column: 50, Additional: ¶ ``` and blender can not do much more than reporting this. I took a brief look at the Collada specifications and actually there is no obvious error in the reported line. Also the reported error does not seem to be correct (there is no additional line break in the data). I will talk to the OpenCollada people to decide how we should handle this issue. However both files can be imported by Blender. I can not confirm that blender hangs during close. Maybe this happened to you because you have marked a line in the console? In that case the console only closes after the mark has been released (very annoying, but it looks like this is Windows behavior and not related to Blender) As a sidenote: I wonder if the scaling in the collada files is correct. I found: ``` <asset> <contributor> <authoring_tool>BrawlBox</authoring_tool> </contributor> <created>2013-11-26T00:40:30Z</created> <modified>2013-11-26T00:40:30Z</modified> <unit meter="0.01" name="centimeter" /> <up_axis>Y_UP</up_axis> </asset> ``` It looks to me like the unit should be: ``` <unit meter="1.0" name="meter" /> ``` At least it makes more sense when looking at the geometry data.
Author
6 Participants
Reference: blender/blender#44648
