Apple right mouse emulation sending incorrect release event. #44739
Closed
opened 2015-05-17 12:07:55 +02:00 by Francesc Juhe · 10 comments
Any Mac OS X
Broken: All
Worked: None
The file source/blender/windowmanager/intern/wm_event_system.c has this code on line 2913
ifdef APPLE
/* rightmouse emulation */
if (U.flag & USER_TWOBUTTONMOUSE) {
  if (event->type == LEFTMOUSE) {
    if (event->val == KM_PRESS && event->oskey) {
      event->type = RIGHTMOUSE;
      event->oskey = 0;
      mmb_emulated = 1;
    else if (event->val == KM_RELEASE) {
      if (mmb_emulated) {
        event->oskey = RIGHTMOUSE;
        event->alt = 0;
      mmb_emulated = 0;
endif
The KM_RELEASE event is clearing alt and returning oskey as RIGHTMOUSE. Shouldn't it clear oskey and return type as RIGHTMOUSE?
      if (mmb_emulated) {
        event->oskey = 0;
      mmb_emulated = 0;
Doesn't produce errors but the event looks wrong.
**System Information** Any Mac OS X **Blender Version** Broken: All Worked: None **Short description of error** The file source/blender/windowmanager/intern/wm_event_system.c has this code on line 2913 # ifdef __APPLE__ ``` /* rightmouse emulation */ if (U.flag & USER_TWOBUTTONMOUSE) { if (event->type == LEFTMOUSE) { if (event->val == KM_PRESS && event->oskey) { event->type = RIGHTMOUSE; event->oskey = 0; mmb_emulated = 1; } else if (event->val == KM_RELEASE) { if (mmb_emulated) { event->oskey = RIGHTMOUSE; event->alt = 0; } mmb_emulated = 0; } } } ``` # endif The KM_RELEASE event is clearing alt and returning oskey as RIGHTMOUSE. Shouldn't it clear oskey and return type as RIGHTMOUSE? ``` else if (event->val == KM_RELEASE) { if (mmb_emulated) { event->type = RIGHTMOUSE; event->oskey = 0; } mmb_emulated = 0; ``` **Exact steps for others to reproduce the error** Doesn't produce errors but the event looks wrong.
Author
Author
Added subscriber: @fjuhec
jens verwiebe was assigned by Bastien Montagne 2015-05-17 12:21:04 +02:00
Added subscriber: @mont29
Please avoid reporting 'suspicious' code as bug… better to do so in our ML (bf-committers) or directly on IRC (#blendercoders on freenode.net).
Jens, can you please check whether this code is correct?
Please avoid reporting 'suspicious' code as bug… better to do so in our ML (bf-committers) or directly on IRC (#blendercoders on freenode.net). Jens, can you please check whether this code is correct?
Added subscriber: @brecht
The code is wrong, but the proposed fix is not enough. It will never actually hit that code path, because of the middle mouse emulation code right above it, so I'll commit a slightly different fix.
Thanks for finding this!
The code is wrong, but the proposed fix is not enough. It will never actually hit that code path, because of the middle mouse emulation code right above it, so I'll commit a slightly different fix. Thanks for finding this!
Author
Yes, both emulations conflict as they use the same status variable 'mmb_emulated' and the first changes the event type preventing the second from doing anythong because the event is no longer a left button. But, that would only be an issue if both alt and oskey are pressed and in that case, what key is the user trying to emulate when alt is for middle button and oskey for right button? The code seems to just give priority to middle mouse emulation over right mouse emulation and it seems to matter only for single button mouse or tabled and mac.
I didn't want to go deeper than noticing the km_release for oskey emulated right button was not sending the right value.
I am curious on the final fix.
Yes, both emulations conflict as they use the same status variable 'mmb_emulated' and the first changes the event type preventing the second from doing anythong because the event is no longer a left button. But, that would only be an issue if both alt and oskey are pressed and in that case, what key is the user trying to emulate when alt is for middle button and oskey for right button? The code seems to just give priority to middle mouse emulation over right mouse emulation and it seems to matter only for single button mouse or tabled and mac. I didn't want to go deeper than noticing the km_release for oskey emulated right button was not sending the right value. I am curious on the final fix.
This issue was referenced by 43ee3f4040
This issue was referenced by 43ee3f4040a41c637b6eceda4c3aa1046f8a13a5
Closed by commit 43ee3f4040.
Reference: blender/blender#44739
