uvmap causes crash when entering texture paint mode #45514
5 Participants
Reference: blender/blender#45514
OS: windows 8.1 64bit
GPU: NVIDIA GTX 860m
Broken:
version 2.75 (sub 2), branch b'master', commit date b'2015-07-17' b'13:15', hash b'955c13d'
when switching to texture paint mode blender crashes. i could pin it down to the uv map, when i remove it i can enter texture paint mode without crashing.
blend file: uvmap_crash.blend
crashlog:
Added subscriber: @DanielGrauer
Added subscriber: @Blendify
Can confirm
Added subscriber: @Psy-Fi
Confirmed, thanks for the report.
I would be very interested to know how this file was created.
The file even crashes on 2.75 official. It's caused by the stencil layer not being there (usually it's the same as the UV layer). Also looks like the stencil layer index is set to 2, while the mesh only has one UV layer. This should be impossible normally. I can add checks in the code to ensure it is within bounds, but best would be to know what caused the file to have this behaviour in the first place.
Added subscriber: @sindra1961
Deletion of Shrinkwrap and Lattice modifier is recorded in crashlog attached in detail, but such modifier is not set in attached .blend file.
Is crashlog a thing recorded with attached .blend file?
Added subscriber: @antony-2
@antony-2: i will see if i can figure out what happened there
@perfection cat: it is the same blend file, i just stripped it down because i can not upload the full scene. but since it also happens when the modifiers are removed i dont think they are relevant to the problem.
uvmaap causes crash when entering texture paint modeto uvmap causes crash when entering texture paint modeso i looked into the scene to see how this came to be, and it has a long history. Models in the scene have been made in the age of 2.49 and were at some point ported to 2.5+, there was a lot of stuff like multiple uvmaps, drivers, and deformation setups with lattices and such that have been removed over the years and also stencil layers.
my best guess is that we manually assigned a uvmap to a stencil layer which later got removed and somehow created this special case.
How was the stencil layer assigned manually? was it through a python script?
The fix I will attempt will do two things:
i think it was manually, i cant remember ever using a script for stencils.
This comment was removed by @DanielGrauer
This issue was referenced by
67e32b3195
Since there is no recollection of how the file was produced and there's such a complicated history, we can do little to fix the real cause of the issue. There is a big chance this won't happen with regular use of recent versions though.
To fix the file, I have added functionality in mesh validation that fixes the invalid indices for you.
Just go to a text editor or a console and run this python script:
thanks a lot for adding the functionality! i also dont think this will happen with recent files and probably not possible to reproduce this without messing with very old blender versions.
