Script autorun closes immediately on Windows #45699
Closed
opened 2015-08-05 23:57:02 +02:00 by Jeremy Nicola · 19 comments
Windows 7, Intel HD Graphics 4000
Bug has been confirmed to appear with other (unkown) graphics cards
Broken: from 2.68
Worked: until 2.67b
On Windows, from Blender 2.68, when running a python script from the command line the blender game engine closes as soon as it starts: the Blender game engine starts, the scene is shown, and it closes and the terminal says "Blender Game engine Stopped".
In the same conditions, the Blender Game Engine runs fine on OSX and Linux.
In a console, in the same folder as the Blender executable, autorun.blend and test.py:
blender -d autorun.blend -y -P test.py
  • On Linux the Game Engine runs and the cube is shown (any version from 2.67a to 2.75a).
  • On OSX Yosemite the Game Engine runs and the cube is shown (tested with 2.75a)
  • On Windows with version 2.67a the Game Engine runs and the cube is shown
  • On Windows with version 2.68 and above the Game Engine closes as soon as it opened and the program terminates.
I think the bug was introduced in commit 412c043474, but I can't confirm.
We are using this option to run robotics simulation using the Game Engine with MORSE (https://www.openrobots.org/morse/doc/latest/morse.html).
A work around on Windows is to uncheck the "Auto start" property of the autorun.blend file in the Game menu, launch the same command as above and then press "p" to launch the simulation (which works).
We would really appreciate if this bug can be fixed, let me know how I can help.
Jeremy Nicola
**System Information** Windows 7, Intel HD Graphics 4000 Bug has been confirmed to appear with other (unkown) graphics cards **Blender Version** Broken: from 2.68 Worked: until 2.67b **Short description of error** On Windows, from Blender 2.68, when running a python script from the command line the blender game engine closes as soon as it starts: the Blender game engine starts, the scene is shown, and it closes and the terminal says "Blender Game engine Stopped". In the same conditions, the Blender Game Engine runs fine on OSX and Linux. **Exact steps for others to reproduce the error** In a console, in the same folder as the Blender executable, [autorun.blend](https://archive.blender.org/developer/F220453/autorun.blend) and [test.py](https://archive.blender.org/developer/F220455/test.py): blender -d autorun.blend -y -P test.py - On Linux the Game Engine runs and the cube is shown (any version from 2.67a to 2.75a). - On OSX Yosemite the Game Engine runs and the cube is shown (tested with 2.75a) - On Windows with version 2.67a the Game Engine runs and the cube is shown - On Windows with version 2.68 and above the Game Engine closes as soon as it opened and the program terminates. I think the bug was introduced in commit 412c043474, but I can't confirm. We are using this option to run robotics simulation using the Game Engine with MORSE (https://www.openrobots.org/morse/doc/latest/morse.html). **A work around on Windows** is to uncheck the "Auto start" property of the [autorun.blend](https://archive.blender.org/developer/F220453/autorun.blend) file in the Game menu, launch the same command as above and then press "p" to launch the simulation (**which works**). We would really appreciate if this bug can be fixed, let me know how I can help. Jeremy Nicola
Author
Author
Added subscriber: @JeremyNicola
Added subscriber: @sindra1961
The Game Engine runs in my environment (win32), and the cube is shown.
{F220478}autorun.log
version 2.75 (sub 4), branch b'master', commit date b'2015-08-04' b'19:56', hash b'd39e188', b'Release'
The Game Engine runs in my environment (win32), and the cube is shown. {[F220478](https://archive.blender.org/developer/F220478/autorun.png)}[autorun.log](https://archive.blender.org/developer/F220480/autorun.log) version 2.75 (sub 4), branch b'master', commit date b'2015-08-04' b'19:56', hash b'd39e188', b'Release'
Author
Well, too bad for the reproductibility :-/...
here is my log with 2.75 on Windows:
debug2.75_windows.txt
you can see that the script "test.py" was not executed as "Hello Blender" does not appear, contrarily to your log.
Well, too bad for the reproductibility :-/... here is my log with 2.75 on Windows: [debug2.75_windows.txt](https://archive.blender.org/developer/F220483/debug2.75_windows.txt) you can see that the script "test.py" was not executed as "Hello Blender" does not appear, contrarily to your log.
Member
Added subscriber: @hg1
Member
The way you are running the script is for Blender scripts not for BGE. So basically it would be a Blender and not a BGE bug if there is really a bug.
Because on my Windows 7 PC with Blender 32 bit version 2.75a it will work and will print "Hello Blender".
Console Output.txt
Please read the documentation about Scripting & Security. Maybe you have to activate Auto Run Python Scripts once to add the parameter to the settings. After that you can disable it and use -y or --enable-autoexec if you want.
http://wiki.blender.org/index.php/Doc%3A2.6/Manual/Extensions/Python/Security
http://wiki.blender.org/index.php/Doc:2.4/Manual/Render/Command_Line
But basically this is not the right way to run a BGE script. The way you are using is to run a Blender script (bpy). And will only run once at startup and will be not called while the the BGE is running. The normal way to run a BGE script is to use a Python module controller and a always sensor.
If you want to start the BGE game from the console you have have to use the Blenderplayer.
"blender -d autorun.blend -y -P test.py" -y and -P are not existing for the Blenderplayer and you can't load a python script like blender Blender script.
So you have to use "blenderplayer -d autorun.blend"
The way you are running the script is for Blender scripts not for BGE. So basically it would be a Blender and not a BGE bug if there is really a bug. Because on my Windows 7 PC with Blender 32 bit version 2.75a it will work and will print "Hello Blender". [Console Output.txt](https://archive.blender.org/developer/F221685/Console_Output.txt) Please read the documentation about Scripting & Security. Maybe you have to activate Auto Run Python Scripts once to add the parameter to the settings. After that you can disable it and use -y or --enable-autoexec if you want. http://wiki.blender.org/index.php/Doc%3A2.6/Manual/Extensions/Python/Security http://wiki.blender.org/index.php/Doc:2.4/Manual/Render/Command_Line But basically this is not the right way to run a BGE script. The way you are using is to run a Blender script (bpy). And will only run once at startup and will be not called while the the BGE is running. The normal way to run a BGE script is to use a Python module controller and a always sensor. If you want to start the BGE game from the console you have have to use the Blenderplayer. "blender -d autorun.blend -y -P test.py" -y and -P are not existing for the Blenderplayer and you can't load a python script like blender Blender script. So you have to use "blenderplayer -d autorun.blend"
Member
Added subscribers: @JorgeBernalMartinez, @ideasman42
Added subscriber: @Sergey
@ideasman42, seems we just need to disable safety features for game engine?
Author
I am able to build from 2.67b (doesn't show the bad behavior) to current release (shows the bad behavior) on Windows.
I am pretty busy at the moment, by the end of the month I will git bisect and report what I found.
I am able to build from 2.67b (doesn't show the bad behavior) to current release (shows the bad behavior) on Windows. I am pretty busy at the moment, by the end of the month I will git bisect and report what I found.
Campbell Barton self-assigned this 2015-09-13 16:45:56 +02:00
This issue was referenced by 5611237391
This issue was referenced by 5611237391db8badf5e64dc559b5ac456631e1de
Changed status from 'Resolved' to: 'Open'
Accidentally pasted in wrong tracker number!
Confirmed the bug, looking into a fix.
Update, its caused by: 24321d4891
Whats happening is the BGE is checking the window is still set in BL_KetsjiNextFrame, see /* window closed while bge runs */.
From commit 24321d4891, the added call to wm_event_do_handlers which sets the window context to NULL.
Confirmed the bug, looking into a fix. Update, its caused by: 24321d4891 Whats happening is the BGE is checking the window is still set in `BL_KetsjiNextFrame`, see `/* window closed while bge runs */`. From commit 24321d4891, the added call to `wm_event_do_handlers` which sets the window context to `NULL`.
This issue was referenced by 3056add0e0
This issue was referenced by 3056add0e0b087f7e08781095fcdd99d08ca8f25
Author
Great, thank you!
Great, thank you!
7 Participants
Reference: blender/blender#45699
