Image Texture Node Clipping Bug #45769
Closed
opened 2015-08-12 14:38:55 +02:00 by Robert M · 11 comments
Debian AMD64, fglrx
Broken: current git
The new "Clip" option for image extrapolation on the Image Texture Node does not clip UVs that are >1.0, which is not correct. (Alpha should be 0.0 here)
On the other hand it does UV clipping for UVs <0.0, which is correct.
If you need an example .blend please tell me, but probably this should be trivial to fix.
Thank you!
**System Information** Debian AMD64, fglrx **Blender Version** Broken: current git **Short description of error** The new "Clip" option for image extrapolation on the Image Texture Node does not clip UVs that are >1.0, which is not correct. (Alpha should be 0.0 here) On the other hand it does UV clipping for UVs <0.0, which is correct. If you need an example .blend please tell me, but probably this should be trivial to fix. Thank you!
Author
Author
Added subscriber: @robertm
Member
Added subscriber: @Blendify
Member
Yes that .blend would be nice
Aaron Carlisle self-assigned this 2015-08-12 23:28:47 +02:00
Aaron Carlisle removed their assignment 2015-08-12 23:29:32 +02:00
Sergey Sharybin was assigned by Aaron Carlisle 2015-08-12 23:29:32 +02:00
Author
[Clipping_bug.blend](https://archive.blender.org/developer/F223805/Clipping_bug.blend)
Author
Press F12 to render it. (The viewport doesn't respect the new "Clip" option. It always has the "Repeat" mode. Maybe I should file a separate bug report for this?)
I'm using a second UV map called decal.
The sphere should mostly be covered by the sand texture. Only in the middle it should have the stone texture.
This is my rendered image:
At the top right of the stone texture it bahaves like the "Extend" option, which should not happen.
Press F12 to render it. (The viewport doesn't respect the new "Clip" option. It always has the "Repeat" mode. Maybe I should file a separate bug report for this?) I'm using a second UV map called decal. The sphere should mostly be covered by the sand texture. Only in the middle it should have the stone texture. This is my rendered image: ![clipping_bug.png](https://archive.blender.org/developer/F223807/clipping_bug.png) At the top right of the stone texture it bahaves like the "Extend" option, which should not happen.
Added subscriber: @mont29
This issue was referenced by aac6ee6b87
This issue was referenced by aac6ee6b870eb968d37c16039e6cdc579df17288
This issue was referenced by blender/cycles@7b957ea88d
This issue was referenced by blender/cycles@7b957ea88d6d2dafeb2a619957c0b338313fc1d2
5 Participants
Reference: blender/blender#45769
