Problem selecting all objects on a layer from a script if any 3d view is in local mode #45783
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#45783
Broken: 2.75a-c27589e 64bit
If any 3d view is in local mode
bpy.ops.object.select_by_layer()
fails to select all objects on the layer. Even if the view is not used anymore.Exact steps for others to reproduce the error
bpy.ops.object.select_by_layer(layers=1)
to python consoleThe strangest part is that if you close the 3d view that is in local mode, the cube cannot still be selected with select_by_layer until you open another 3d view set it to local mode with the cube and back to global mode.
Added subscriber: @suikki
Added subscriber: @mont29
That’s because local view uses additional bitflag on layer… Does not make much sense to prevent selection in this case though, easy fix.
This issue was referenced by blender/blender@d2383ec6c0
