Cycles Point Density Texture object space wrong mapping for scale #46301
Closed
opened 2015-09-28 11:04:43 +02:00 by Gottfried Hofmann · 12 comments
Ubuntu 15.04 Geforece GTX 580
Broken: 2.76rc2
Using object space for point density results in wrong scale, see attached image (the cube was scaled in edit mode and has scale 1.0 but dimensions 10.0. pd.bug.scale.png
Using world space yields the correct result.
Open attached .blend, render or turn on rendered view in viewport.
**System Information** Operating system and graphics card Ubuntu 15.04 Geforece GTX 580 **Blender Version** Broken: 2.76rc2 **Short description of error** Using object space for point density results in wrong scale, see attached image (the cube was scaled in edit mode and has scale 1.0 but dimensions 10.0. ![pd.bug.scale.png](https://archive.blender.org/developer/F240399/pd.bug.scale.png) Using world space yields the correct result. **Exact steps for others to reproduce the error** Open attached .blend, render or turn on rendered view in viewport.
Added subscriber: @GottfriedHofmann
Added subscriber: @Sergey
I would be happy to solve the issue, but i don't really see attached .blend file.
pd.object.coords.bug.blend
Sorry for that, try the above one.
[pd.object.coords.bug.blend](https://archive.blender.org/developer/F240480/pd.object.coords.bug.blend) Sorry for that, try the above one.
Added subscriber: @zeauro
I confirm that same problem is visible for object vertices.
PD_WS_OS.blend
It seems that Worldspace is limited to a volume of 2X2X2 BU and Objectspace is just increasing this result to mesh bounding box.
I confirm that same problem is visible for object vertices. [PD_WS_OS.blend](https://archive.blender.org/developer/F240497/PD_WS_OS.blend) It seems that Worldspace is limited to a volume of 2X2X2 BU and Objectspace is just increasing this result to mesh bounding box.
Sergey Sharybin self-assigned this 2015-09-28 18:05:34 +02:00
@GottfriedHofmann, your issue should be now fixed in 4c09f47.
@zeauro, this is a bit pf limitation of how Cycles samples density of an object -- it uses texture space to get boundaries within which sampling should happen. Will check if this could become more reliable.
@GottfriedHofmann, your issue should be now fixed in 4c09f47. @zeauro, this is a bit pf limitation of how Cycles samples density of an object -- it uses texture space to get boundaries within which sampling should happen. Will check if this could become more reliable.
The issue indeed got fixed by 4c09f47
Reference: blender/blender#46301
