continuous grab causes jumping behavior of mouse cursor while adjusting values in sliders #46306
Reference: blender/blender#46306
Windows 7, NVIDIA Quadro 1000m
Broken: 2.75 RC
c586e30
Worked:
If you click on a the right side of a value slider while the cursor is moving at all, the cursor jumps to the left side of the slider. Sometimes it adjusts the value as well as enabling you to type in a value. Sometimes while adjusting nodes in the node editor, clicking the slider to edit the value numerically will work, but the cursor will have popped to the left and sit on top of the numbers. It occasionally drags values in an undesirable way before snapping over, which is undesirable in itself.
Note: I downloaded 2.75 to check and this happens there too. Just wanted to mention that I never knew about continuous grab until recently, and enabled it shortly before the first 2.76 release candidate. Apologies if this is a dud but this isn't very desirable behavior. Continuous grab is an amazing feature for which I am grateful (thanks to whoever thought that up!!!), and this seems to happen only while it is enabled. Apologies if it seems like I'm trying to have cake and eat it too, but this has been driving me batty since I enabled continuous grab.
Added subscriber: @JimCantley
Anyone know how I can edit? Wanted to straighten up some things in this report but when I click "edit task" it says
You do not have permission to edit this object.
Users with the "Can Edit" capability:
Members of the project "Moderators" can take this action.
The owner of a task can always view and edit it.
I seem able to edit comments OK.
Added subscriber: @ideasman42
Note that this may be a duplicate of #44605
Even though its not identical, it may be the same root cause.
This issue was referenced by
491b1899de
Committed fix for the issue where the cursor is re-positioned to inner value indicator even though text editing was started (
491b1899de
). Also, number slider buttons now have a 3 px threshold before dragging is started (32365bb06c
), just like it's done for normal number buttons.I personally also don't really like that we set the cursor to the inner value indicator after dragging. It's a bit annoying if you start dragging from the right and the cursor reappears on the far left, but this shouldn't be discussed here.
This sounds like a bug, and almost certain this was never intended behavior.
Testing here and the cursor isn't warping when dragging numbers.
In what situation does this happen?
It happens for me any time at all when the mouse is moving and you're adjusting a slider without arrows on the sides (see sliders in screenshot); the cursor jumps/warps over to the left of the slider. It only happens when continuous grab is enabled, like it makes its own continuous grab area inside the area of a slider (guessing here and don't want to lead anyone astray but depending on how long you drag, it changes the position of the cursor, like if you drag it a small bit, it resets farther to the left in the slider).
It only seems to happen on sliders without arrows, like strength of a bump node. And the lower the value in the slider, the bigger the warp seems to be! If the strength in bump node, is at like .01 for example, and you slide, it warps farther to the left. If the strength is at .999 it doesn't really warp. Quite odd but that's what I'm experiencing.
I downloaded RC3 and it seems like the issue of clicking to enter a number and the cursor jumping has been resolved.. I think... :P Seemed to be a couple of things going on. Thanks again severin.
Oooh yeah, that's nice. And thanks to whoever made it so that we can slide at thousands place of decimals. That's incredible!
Hmm, seems that you can only adjust decimals to the thousands in sliders without arrows. I really miss being able to do that, that is such a helpful feature. As a casual request, any chance to plop that functionality into other sliders? Quite often I find myself manually entering .001, no OK, .002, no OK :(
