Hide/Mask menu, Hotkey for lasso mask in sculpt mode unchangeable #46346
Reference: blender/blender#46346
Windows 7 Home 64 Bit
GTX 760
Broken: (example: 2.69.7
4b206af
, see splash screen)Worked: (optional)
Blender 2.76 RC3
You cannot change the hotkey for the lasso mask in the rmb menu of the menu item. It shows the hotkey Shift Ctrk Left mouse. Normally when you have a menu item with a hotkey assigned, then you have a menu entry in the RMB menu called change shortcut. But in the right click menu for Lasso Mask you just see a Add Shortcut item. And when you try to change the hotkey, then nothing happens.
Start Blender. Select the standard cube (or create one). Switch into Sculpt mode. Go to Hide/Mask and right click at Lasso Mask. Try to change the hotkey.
Added subscriber: @tiles
Added subscriber: @mont29
Yep, logic here is broken in UI code (note that you can only edit 'keybaord' shortcuts, the others should show no add nor edit/remove options, will also add a warning/info entry here instead for those non-keyboard case).
This issue was referenced by
e49b934955
