Python: bvh.ray_cast doesn't find a plane facing in the other direction under certain circumstances #46521
5 Participants
Reference: blender/blender#46521
Windows 7 64 bit
Nvidia Quadro 600
Broken:
bfdb420
The ray_cast function returns (None, None, ..) although there is a polygon.
bvh_bug.blend
In the file is a python script, when you execute it you will find that it prints "None" in the Console, but instead it should print "<Vector (4.0000, 0.0000, 0.0000)>"
There are multiple things you can do so that the function finds the plane:
Added subscriber: @mont29
There is also another thing you can do here - increase epsilon of bvhtree (even such a small value as 1e-9 is enough)…
Will check further what happens here, but this may be due to numeric instability/imprecision, which is precisely why non-zero epsilon is usually needed. ;)
Added subscriber: @Sergey
OK, so issue is with
isect_ray_tri_watertight_v3()
not detecting rayhit on a border (remember your square is split in two triangles, which means your ray would hit exactly on the limit between those two tris).Now, I won’t pretend to understand that dark piece of art of black magic that is watertight, so will let @Sergey decide whether this is known limitation/expected behavior, or actual real bug.
Watertight intersection is aimed to solve issues caused by ray hitting exact edge. There's one difference from the original paper which is fallback to double precision in the cease if
U == 0.0f || V == 0.0f || W == 0.0f
. We don't do this in Cycles because doubles aren't available in consumer GPUs and doing float to double precision conversion is not really cheap. But here i think we should implement such a fallback.Added subscriber: @ideasman42
Tested and even after adding the double fallback its still returning
None
, see: P274This issue was referenced by
0d54aa9c02
