Drivers do not work in node groups. #46587
7 Participants
Reference: blender/blender#46587
Windows 7 64 bit with 64 bit Blender
Broken: 2.76.2
fbca69c
Drivers do not work, when they are inside a node group.
(Didn't test it outside the compositor.)
bug.blend
The value node on the top left (labeled "#frame") has a driver which takes the current frame number.
The group node below contains a value node also has a driver, and should output the current frame number. But this does NOT work.
So you can see it, if you render, the output of the group node is displayed on the left; the output of the (ungrouped) value node is displayed on the right.
Added subscriber: @Foaly
Added subscriber: @Sergey
This is something which can't really work in the old depsgraph but something i would expect to work in the new one. Need to have some closer look tho.
This issue was referenced by
97c8619b42
Added subscriber: @mrburns
Hi,
the problem still exists!
I have the x value of a blur node driven by the Z location of the default cube. This works.
But if I put the blur node into a group then it does not work anymore, the x value is always zero.
My Blender version is 2.76b, Date 2015-11-03- 10:56, Hash
f337fea
.I use the Windows 64 bit version
Best regards,
Mr. Burns
Hi,
I also tested with version 2.76 Date 2016-01-20 00:43 hash
bda0820
, but still the same. The Z location of the cube is 2.15.The blur node inside group does not update the x value. It shows 3.
The blur node out of group does it correctly. It shows 2.
(both use same driver)
If this doesn't work after switching to the new dependency graph, then please make a new bug report including all the details and .blend file demonstrating the problem.
@mrburns, you need to explicitly enable the new dependency graph by launching Blender from the command line with the
--enable-new-depsgraph
argument.Added subscriber: @lukas.remis
Changed status from 'Resolved' to: 'Open'
This bug is still present in 2.79b (Mac version)drivers_error.blend.
Attaching test file. I try to drive some values inside a group with the input value from the group node.
Tried starting Blender with --enable-new-depsgraph - still drivers do not work in node groups.
Please make a simple file where it's clear which exact drivers do not work. If it's possible top reproduce with one driver, that'd be way more clear to understand desired behavior.
In this example some of the drivers are actually set to constant values, and some other drivers are trying to drive nodes of same node tree. Note that this should probably work, but chained drivers are not yet supported (as in, node_a drivers node_b and node_b drives node_c of the same tree).
Added subscriber: @lichtwerk
Since last asking for information it has been 7 or more days, due to the policy of our bug tracker we will have to archive the report until the requested information is given.
