OpenSubdiv misbehavior and crash with vertex-parented children and drivers. #46589
Closed
opened 2015-10-24 19:20:46 +02:00 by Alexander Gavrilov · 6 comments
Fedora 21, GeForce GT 640
Broken: 2.76
If an object has vertex-parented children, OpenSubdiv can still be enabled but the objects shift around in weird ways. Also, if Use OpenSubdiv is toggled via driver, it will intermittently crash.
Load this file: test-subdiv-driver.blend
The selected bone has an 'opensubdiv' property, which controls the checkbox on the middle cube subdiv modifier via driver.
  • Toggling it from 0 to 1 makes the small cubes move around.
  • Toggling it enough times (most conveniently done by dragging the field and shaking the mouse left-right) crashes blender. Strangely, it doesn't happen if toggling the checkbox directly.
P.S. Just before submitting I found that the crash still happens eventually even if I delete the child objects, so these may be unrelated problems.
**System Information** Fedora 21, GeForce GT 640 **Blender Version** Broken: 2.76 **Short description of error** If an object has vertex-parented children, OpenSubdiv can still be enabled but the objects shift around in weird ways. Also, if Use OpenSubdiv is toggled via driver, it will intermittently crash. **Exact steps for others to reproduce the error** Load this file: [test-subdiv-driver.blend](https://archive.blender.org/developer/F247167/test-subdiv-driver.blend) The selected bone has an 'opensubdiv' property, which controls the checkbox on the middle cube subdiv modifier via driver. * Toggling it from 0 to 1 makes the small cubes move around. * Toggling it enough times (most conveniently done by dragging the field and shaking the mouse left-right) crashes blender. Strangely, it doesn't happen if toggling the checkbox directly. P.S. Just before submitting I found that the crash still happens eventually even if I delete the child objects, so these may be unrelated problems.
Author
Member
Author
Member
Added subscriber: @angavrilov
Added subscriber: @Sergey
Sergey Sharybin self-assigned this 2015-10-27 16:38:41 +01:00
The issue with vertex parent was fixed in 7e7527d. The issue with driver happens because of drivers are evaluated from the threads, making it likely to crash with OpenSubdiv due to OpenGL access from several threads. This still needs work.
This issue was referenced by a5f4f1e2ce
This issue was referenced by a5f4f1e2cea831415c045be4927320dc060798c9
Reference: blender/blender#46589
