crash with generating DataBlockPreviews #46626
Closed
opened 2015-10-28 15:46:41 +01:00 by Philipp Oeser · 9 comments
Member
linux64, Titan
Broken: b0bce65d67
Worked: f375028a25
crash with generating DataBlockPreviews in the default scene
in default startup file [might have to start blender with --factory], goto
File > Data Previews > Refresh DataBlock Previews
should crash
Caused by a broken(freed?) "toggle_brush" pointer on the "SculptDraw" brush.
So you will only get the crash if the "SculptDraw" brush is selected in sculptmode (which I think it is in the default startup scene)
If any other brush is selected, crash wont happen.
this will prevent the crash
diff --git a/source/blender/blenkernel/intern/library_query.c b/source/blender/blenkernel/intern/library_query.c
--- a/source/blender/blenkernel/intern/library_query.c
+++ b/source/blender/blenkernel/intern/library_query.c
@@ -533,7 +533,7 @@ void BKE_library_foreach_ID_link(ID *id, LibraryIDLinkCallback callback, void *u
 		case ID_BR:
 			Brush *brush = (Brush *) id;
-			CALLBACK_INVOKE(brush->toggle_brush, IDWALK_NOP);
+			//CALLBACK_INVOKE(brush->toggle_brush, IDWALK_NOP);
 			CALLBACK_INVOKE(brush->clone.image, IDWALK_NOP);
 			CALLBACK_INVOKE(brush->paint_curve, IDWALK_USER);
 			library_foreach_mtex(&data, &brush->mtex);
backtrace
Thread 1 (Thread 0x7fffeae25b00 (LWP 30940)):
#0  0x0000000001c9231a in previews_id_ensure_callback (todo_v=0x7fffffffdca0, idptr=0x6f0ef00, UNUSED_cd_flag=0) at /blender/source/blender/windowmanager/intern/wm_operators.c:5043
        todo = 0x7fffffffdca0
        id = 0x7f1eb19a5c08
#1  0x00000000029531ca in BKE_library_foreach_ID_link (id=0x6f0ebe8, callback=0x1c922e5 <previews_id_ensure_callback>, user_data=0x7fffffffdca0, flag=1) at /blender/source/blender/blenkernel/intern/library_query.c:538
        old_id = 0x7f1eb19a5c08
        keep_working = false
        brush = 0x6f0ebe8
        adt = 0x0
        data = {self_id = 0x6f0ebe8, flag = 1, callback = 0x1c922e5 <previews_id_ensure_callback>, user_data = 0x7fffffffdca0}
        i = 0
        __func__ = "BKE_library_foreach_ID_link"
valgrind
==31752== Invalid read of size 2
==31752==    at 0x1C9231A: previews_id_ensure_callback (wm_operators.c:5043)
==31752==    by 0x29531C9: BKE_library_foreach_ID_link (library_query.c:538)
==31752==    by 0x1C924D6: previews_ensure_exec (wm_operators.c:5076)
==31752==    by 0x1C75038: wm_operator_invoke (wm_event_system.c:1103)
==31752==    by 0x1C75603: wm_operator_call_internal (wm_event_system.c:1288)
==31752==    by 0x1C757F3: WM_operator_name_call_ptr (wm_event_system.c:1336)
==31752==    by 0x1FAA00E: ui_apply_but_funcs_after (interface_handlers.c:755)
==31752==    by 0x1FC33F1: ui_handler_region_menu (interface_handlers.c:9816)
==31752==    by 0x1C7365F: wm_handler_ui_call (wm_event_system.c:453)
==31752==    by 0x1C77159: wm_handlers_do_intern (wm_event_system.c:2022)
==31752==    by 0x1C773F5: wm_handlers_do (wm_event_system.c:2106)
==31752==    by 0x1C77F11: wm_event_do_handlers (wm_event_system.c:2389)
==31752==  Address 0x7f1eb19a5c6a is not stack'd, malloc'd or (recently) free'd
**System Information** linux64, Titan **Blender Version** Broken: b0bce65d67ac65bef114cdf22e66f997b4028269 Worked: f375028a2542981732aef6ce4700aa951325e63d **Short description of error** crash with generating DataBlockPreviews in the default scene **Exact steps for others to reproduce the error** in default startup file [might have to start blender with --factory], goto File > Data Previews > Refresh DataBlock Previews should crash Caused by a broken(freed?) "toggle_brush" pointer on the "SculptDraw" brush. So you will only get the crash if the "SculptDraw" brush is selected in sculptmode (which I think it is in the default startup scene) If any other brush is selected, crash wont happen. this will prevent the crash ``` diff --git a/source/blender/blenkernel/intern/library_query.c b/source/blender/blenkernel/intern/library_query.c --- a/source/blender/blenkernel/intern/library_query.c +++ b/source/blender/blenkernel/intern/library_query.c @@ -533,7 +533,7 @@ void BKE_library_foreach_ID_link(ID *id, LibraryIDLinkCallback callback, void *u case ID_BR: { Brush *brush = (Brush *) id; - CALLBACK_INVOKE(brush->toggle_brush, IDWALK_NOP); + //CALLBACK_INVOKE(brush->toggle_brush, IDWALK_NOP); CALLBACK_INVOKE(brush->clone.image, IDWALK_NOP); CALLBACK_INVOKE(brush->paint_curve, IDWALK_USER); library_foreach_mtex(&data, &brush->mtex); ``` backtrace ``` Thread 1 (Thread 0x7fffeae25b00 (LWP 30940)): #0 0x0000000001c9231a in previews_id_ensure_callback (todo_v=0x7fffffffdca0, idptr=0x6f0ef00, UNUSED_cd_flag=0) at /blender/source/blender/windowmanager/intern/wm_operators.c:5043 todo = 0x7fffffffdca0 id = 0x7f1eb19a5c08 #1 0x00000000029531ca in BKE_library_foreach_ID_link (id=0x6f0ebe8, callback=0x1c922e5 <previews_id_ensure_callback>, user_data=0x7fffffffdca0, flag=1) at /blender/source/blender/blenkernel/intern/library_query.c:538 old_id = 0x7f1eb19a5c08 keep_working = false brush = 0x6f0ebe8 adt = 0x0 data = {self_id = 0x6f0ebe8, flag = 1, callback = 0x1c922e5 <previews_id_ensure_callback>, user_data = 0x7fffffffdca0} i = 0 __func__ = "BKE_library_foreach_ID_link" ``` valgrind ``` ==31752== Invalid read of size 2 ==31752== at 0x1C9231A: previews_id_ensure_callback (wm_operators.c:5043) ==31752== by 0x29531C9: BKE_library_foreach_ID_link (library_query.c:538) ==31752== by 0x1C924D6: previews_ensure_exec (wm_operators.c:5076) ==31752== by 0x1C75038: wm_operator_invoke (wm_event_system.c:1103) ==31752== by 0x1C75603: wm_operator_call_internal (wm_event_system.c:1288) ==31752== by 0x1C757F3: WM_operator_name_call_ptr (wm_event_system.c:1336) ==31752== by 0x1FAA00E: ui_apply_but_funcs_after (interface_handlers.c:755) ==31752== by 0x1FC33F1: ui_handler_region_menu (interface_handlers.c:9816) ==31752== by 0x1C7365F: wm_handler_ui_call (wm_event_system.c:453) ==31752== by 0x1C77159: wm_handlers_do_intern (wm_event_system.c:2022) ==31752== by 0x1C773F5: wm_handlers_do (wm_event_system.c:2106) ==31752== by 0x1C77F11: wm_event_do_handlers (wm_event_system.c:2389) ==31752== Address 0x7f1eb19a5c6a is not stack'd, malloc'd or (recently) free'd ```
Author
Member
Author
Member
Added subscriber: @lichtwerk
Added subscribers: @mont29, @Sergey
@mont29, it is possible that brush->toggle_brush pointer is becoming invalid. For example, you toggle brush then you remove original one. Also, not really sure you really want to go into toggle brush itself in the walker, so leaving it up to you.
@mont29, it is possible that `brush->toggle_brush` pointer is becoming invalid. For example, you toggle brush then you remove original one. Also, not really sure you really want to go into toggle brush itself in the walker, so leaving it up to you.
Bastien Montagne was assigned by Sergey Sharybin 2015-10-28 16:25:54 +01:00
Added subscriber: @afdave14
I do not see how we can accept an invalid pointer here? It may crash in many other cases I guess? Even worse in default startup, this should be fixed in factory .blend…
And the walker shall return all ID pointers, with no exceptions - otherwise you'll end up with even more 'invalid pointers' like that in the future.
Think this is a good demo of how bad our 'remove ID' code is currently :|
That said, will have a look around to try to understand how toggle_brush can become invalid - and tease Campbell to fix startup file.
I do not see how we can accept an invalid pointer here? It may crash in many other cases I guess? Even worse in default startup, this should be fixed in factory .blend… And the walker shall return all ID pointers, with no exceptions - otherwise you'll end up with even more 'invalid pointers' like that in the future. Think this is a good demo of how bad our 'remove ID' code is currently :| That said, will have a look around to try to understand how toggle_brush can become invalid - and tease Campbell to fix startup file.
Added subscriber: @ideasman42
Removed subscriber: @afdave14
Added subscriber: @ideasman42 Removed subscriber: @afdave14
This issue was referenced by 7b7aba31f2
This issue was referenced by 7b7aba31f24d51c904c76a17ee50608b770e1bc9
5 Participants
Reference: blender/blender#46626
