EXR Compression method set in UI does not always get passed correctly to the actual OpenEXR writing code #46826
Closed
opened 2015-11-20 10:32:47 +01:00 by Greg Zaal · 6 comments
Member
Windows 10 64 bit, 980TI
Broken: Recent master (cb1cb63)
When saving a render to the OpenEXR format, all the codecs (except the first two- [x]) produce files of exactly the same size. This makes me think that none of them are actually doing any compression.
I tested both RGB and RGBA, Float (Half) and Float (Full) - the Codec option still makes no difference.
  • DWAB and DWAA seem to be the only codecs that produce different size files.
Save any image (e.g. a render of the default cube) several times using the OpenEXR format, and set the Codec to something different each time.
Here's a zip of my own test: exr_test.zip
**System Information** Windows 10 64 bit, 980TI **Blender Version** Broken: Recent master (cb1cb63) **Short description of error** When saving a render to the OpenEXR format, all the codecs (except the first two- [x]) produce files of exactly the same size. This makes me think that none of them are actually doing any compression. I tested both RGB and RGBA, Float (Half) and Float (Full) - the Codec option still makes no difference. - [x] DWAB and DWAA seem to be the only codecs that produce different size files. **Exact steps for others to reproduce the error** Save any image (e.g. a render of the default cube) several times using the OpenEXR format, and set the Codec to something different each time. Here's a zip of my own test: [exr_test.zip](https://archive.blender.org/developer/F256355/exr_test.zip)
Author
Member
Author
Member
Added subscriber: @GregZaal
Added subscriber: @mont29
The problem is not with OpenEXR compression, but within Blender somewhere, OpenEXR is not always called with the compress option actually shown in UI, not sure yet why… :/
Bastien Montagne changed title from EXR Compression methods don't work to EXR Compression method set in UI does not always get passed correctly to the actual OpenEXR writing code 2015-11-20 18:10:02 +01:00
Bastien Montagne self-assigned this 2015-11-20 18:10:02 +01:00
This issue was referenced by 9a2290a30b
This issue was referenced by 9a2290a30b478f6bf0863796d8129b9fe7e368f1
Reference: blender/blender#46826
