OSL Memory Corruption (Use after free) #47008
Reference: blender/blender#47008
Windows x64
Broken: Latest from git
Tricky one but I'll try to give a short tour.
in Session::~Session() we have this piece of code
Now here's the setup:
[With visual studio]
Tracking it down is a little harder, you have to enable the PageHeap for the process using gflags, once enabled, setup vs.net to catch exception c0000005 (access violation) (something is eating is so it doesn't break by default) and you should hit the exception in blender-app.exe!OSL::pvt::PeakCounter::operator+=(int sz)
suggested fix:
But given i'm unfamiliar with this piece of code i'm unsure if this will create other problems. (doesn't seem like it, but a sober second look never hurts)
Added subscriber: @LazyDodo
Added subscriber: @Sergey
Session is expected to be destroyed only when all the rendering is done, it should not really be destroyed prior to that. This could be just missing de-initialization happening somewhere else in the code, but it's hard to tell without being able to reproduce the issue (don't see anything running blender with )
What are the exact steps reproducing the issue? Does it happen with any scene?
no problem there, the session is destroyed at an appropriate moment in time, when all rendering is completed.
The repro steps i posted should be detailed enough to reproduce the issue on windows. Step 2 should have been 2) Render any scene with osl enabled . I noticed my mistake 2 minutes seconds after i posted but it wouldn't allow me to change it.
so more detailed recap for msvc
If you're not on windows it'll have to go a little bit more on faith but i think this should prove the problem exists:
Ok, see what's happening now. Even tho we're doing all proper ownership management OSL is being lazy and uses some per-thread variables. This is happening, for example, when performing shader group optimization.
Those variables will only be freed when thread is actually exiting and there seems to be no way to force clear the storage neither from the per-thread-variable wrapper (meaning, ShadingSystemImpl can't ensure there's no handling per-thread-variables from it's destructor) and there's also no way to force such storage to clear without actually destroying the thread.
Now, your patch will work around the problem in the case when we've got single render at a time, but it'll totally fail when doing several viewport renderings or when mixing viewport and final render.
This needs some further investigation, maybe even extending OSL/boost API?
One idea which might work (and in fact it seems to work on Linux, judging from debug prints and clang's asan there's no heisenbugs here) is to perform jit optimization ahead of a time using
ShadingSystem->optimize_all_groups()
with couple of therads used. This will make it so OSL creates threads pool and optimzation will use it's TLS. Once optimization is done, all TLS used by optimization will be freed. After that render threads will not create ShadingContext in TLS anymore.While it's working as expected on Linux, it's still failing on Windows. Could be so OSL is still storing something in TLS for the case of Windows platform. What's also weird, disablign
greedyjit
does not solve memory access issues on WIndows, so it's probably something else is happening with threads.Ok, had a mistake in original greedyjut change i was talking about yesterday. This patch should solve the bad memory access:
P304: Fix #47008
It's not totally optimal from the performance point of view, but unless i'm wrong it'll only be some constant delay before the rendering actually starts.
This issue was referenced by
a3df65dea8
This issue was referenced by blender/cycles@626e479945
