Shadow pass error: Black shadow #47025
Closed
opened 2015-12-20 21:57:00 +01:00 by Alexey · 9 comments
Broken: (all)
Worked: (none)
black_shadow_bug.blend
open, render - we will see unneed texture in shadow pass
switch off this texture(or correct it's value level) - proper result
set to any material diffuse color with value more than zero - proper result
set to any material diffuse color with value equal zero - bug
P.S. i don't know what about Cycles render - i don't learn cycles
**System Information** Operating system and graphics card **Blender Version** Broken: (all) Worked: (none) **Short description of error** ![1.png](https://archive.blender.org/developer/F269855/1.png) ![2.png](https://archive.blender.org/developer/F269857/2.png) ![3.png](https://archive.blender.org/developer/F269859/3.png) ![4.png](https://archive.blender.org/developer/F269861/4.png) ![5.png](https://archive.blender.org/developer/F269863/5.png) **Exact steps for others to reproduce the error** [black_shadow_bug.blend](https://archive.blender.org/developer/F269865/black_shadow_bug.blend) open, render - we will see unneed texture in shadow pass switch off this texture(or correct it's value level) - proper result set to any material diffuse color with value more than zero - proper result set to any material diffuse color with value equal zero - bug P.S. i don't know what about Cycles render - i don't learn cycles
Author
Author
Added subscriber: @Inwader77
Author
![6.png](https://archive.blender.org/developer/F269868/6.png)
Added subscriber: @mont29
Main issue here was caused by shadow pass being skipped when diffuse was pitch black - makes sense if you only use that pass internally, since it’s useless with black diffuse color, but not when you want shadow pass for itself. Fix for that is incoming.
Issue with picture tex being noisy I still so not understand…
Main issue here was caused by shadow pass being skipped when diffuse was pitch black - makes sense if you only use that pass internally, since it’s useless with black diffuse color, but not when you want shadow pass for itself. Fix for that is incoming. Issue with picture tex being noisy I still so not understand…
Texture noise comes from some 'instability' of aniso filtering, which generates some pixels with not exactly 1.0 alpha values like 0.999999940395355
Enough for this evening! :P
Texture noise comes from some 'instability' of aniso filtering, which generates some pixels with not exactly 1.0 alpha values like `0.999999940395355`… Enough for this evening! :P
Author
similar behavior we will have in #45214 and in #47033 max saturation material(without texture) - we will see this color in shadow pass,
use texture - we will see max saturation area only. If we use image testure - we will have this noize.
similar behavior we will have in #45214 and in #47033 max saturation material(without texture) - we will see this color in shadow pass, use texture - we will see max saturation area only. If we use image testure - we will have this noize.
Bastien Montagne self-assigned this 2016-01-24 11:15:44 +01:00
OK, so issue is basically how final shadow pass is being generated by internal, reconstructing it from a diffuse + shadow data. This works OK(ish) in common cases, but will break in all corner cases like pitch black (0.0f), fully saturated (1.0f) colors, etc. Fixing it would most likely require to keep a separated , only-shadow pass, which is totally outside of bug fixing scope - and quite unlikely to ever happen actually, given we do not do any new development for BI… Thanks for the report anyway.
2 Participants
Reference: blender/blender#47025
