Particles in Particle Edit Mode get added in completely wrong location #47038
Closed
opened 2015-12-22 12:02:44 +01:00 by Andy Goralczyk · 12 comments
Member
When adding particles in Particle Edit mode using the Add brush, they appear in entirely different location. This used to work in 2.70, in 2.71 it broke somehow.
Sometimes this can be fixed by disabling the subsurf modifier that comes before the particle system. However, having subsurf and particles work together is vital!
oti_particle_edit_mode.blend
See attached file. This file should have a character base mesh already with a particle system, and the Add Particles tool enabled. To repeat the error, simply add particles by drawing on the mesh.
Tested using Blender Institute Linux workstation. Tracked down past working version using the windows builds from download.blender.org
Broken: 2.71 and after
Worked: pre 2.70
When adding particles in Particle Edit mode using the Add brush, they appear in entirely different location. This used to work in 2.70, in 2.71 it broke somehow. Sometimes this can be fixed by disabling the subsurf modifier that comes before the particle system. However, having subsurf and particles work together is vital! [oti_particle_edit_mode.blend](https://archive.blender.org/developer/F270020/oti_particle_edit_mode.blend) See attached file. This file should have a character base mesh already with a particle system, and the Add Particles tool enabled. To repeat the error, simply add particles by drawing on the mesh. **System Information** Tested using Blender Institute Linux workstation. Tracked down past working version using the windows builds from download.blender.org **Blender Version** Broken: 2.71 and after Worked: pre 2.70
Author
Member
Author
Member
Added subscriber: @eyecandy
Bastien Montagne self-assigned this 2015-12-22 13:01:59 +01:00
Added subscriber: @dfelinto
This bug was introduced in eca6264a
Bastien Montagne was unassigned by Dalai Felinto 2015-12-22 13:08:46 +01:00
Antonis Ryakiotakis was assigned by Dalai Felinto 2015-12-22 13:08:46 +01:00
Added subscriber: @mont29
Antony, could you look at this?
I'll try. No promises, the system there is pretty broken.
Issue comes from the fact we are using only mesh_get_derived_deform() in brush_add()… So painting is done without subsurf modifier at all - and add_pars- [x].num_dmcache is set wint deform-only indices (which sounds pretty much useless).
I tried using mesh_get_derived_final() instead, now add_brush() produces valid mapped index values in num_dmcache, but shows nothing on screen (which makes me believe code drawing particles later on expects deform-only indices, but then, why isn’t it mapping correctly to complete DM?). Still investigating…
Issue comes from the fact we are using only `mesh_get_derived_deform()` in `brush_add()`… So painting is done without subsurf modifier at all - and `add_pars- [x].num_dmcache` is set wint deform-only indices (which sounds pretty much useless). I tried using `mesh_get_derived_final()` instead, now `add_brush()` produces valid mapped index values in `num_dmcache`, but shows nothing on screen (which makes me believe code drawing particles later on expects deform-only indices, but then, why isn’t it mapping correctly to complete DM?). Still investigating…
@Psy-Fi if you could have a look at my patch and see whether I did not do complete crap… ;)
@eyecandy can you please check the patch (D1685) and confirm it works for you (and does not break something else :| )?
@Psy-Fi if you could have a look at my patch and see whether I did not do complete crap… ;) @eyecandy can you please check the patch ([D1685](https://archive.blender.org/developer/D1685)) and confirm it works for you (and does not break something else :| )?
Antonis Ryakiotakis was unassigned by Bastien Montagne 2015-12-23 20:02:44 +01:00
Bastien Montagne self-assigned this 2015-12-23 20:02:44 +01:00
Added subscriber: @Psy-Fi
This issue was referenced by aad24468e2
This issue was referenced by aad24468e2d32d46e2c3b3b4a37302a4f1f27ab6
5 Participants
Reference: blender/blender#47038
