Transfer Weights options changed; manual does not reflect #47173
Closed
opened 2016-01-13 03:20:47 +01:00 by Robert Travis · 6 comments
Windows 10 NVIDIA
Broken: 2.76
Following advice of tutorials for previous versions, I saw that Transfer Weights options had changed; I checked the manual for my version (2.76), and it still listed the same options as the tutorials, but those options are not present in the program (specifically this page: https://www.blender.org/manual/painting_sculpting/painting/weight_paint/tools.html?highlight=transfer%20weights)
It says that the options "Group," "Method," and "Replace" are present, but they are not present in the software under "Transfer Weights."
Select 2 objects, one weighted.
Go to Weight Paint mode.
Click on Transfer Weights
- compare interface with user manual -- the options do not match.
**System Information** Windows 10 NVIDIA **Blender Version** Broken: 2.76 Worked: (optional) **Description** Following advice of tutorials for previous versions, I saw that Transfer Weights options had changed; I checked the manual for my version (2.76), and it still listed the same options as the tutorials, but those options are not present in the program (specifically this page: https://www.blender.org/manual/painting_sculpting/painting/weight_paint/tools.html?highlight=transfer%20weights) It says that the options "Group," "Method," and "Replace" are present, but they are not present in the software under "Transfer Weights." **Exact steps for others to reproduce the error** Select 2 objects, one weighted. Go to Weight Paint mode. Click on Transfer Weights - compare interface with user manual -- the options do not match.
Author
Author
Added subscriber: @hindemith
Bastien Montagne was assigned by Campbell Barton 2016-01-13 05:44:31 +01:00
Member
Added subscriber: @Blendify
I wonder a bit why it was assigned to me… This is doc work, change was noted in release notes when it happened (2.74 or 2.75 iirc). Will make quick edit to manual. :/
This issue was referenced by 1190
Reference: blender/blender-manual#47173
