Region selection tools (box, circle, lasso) select extra vertices #47204
6 Participants
Reference: blender/blender#47204
Linux 64bit, NVIDIA GTS 450, driver 355.11
Broken: 2.76b, 2.76
c6bc236
This video (0.6Mb, 35 seconds) shows the erroneous behaviour:
https://www.dropbox.com/s/2ra3drex8ivah22/selection.mp4?dl=0
Note, this happens when multisampling is off. On my system, if I turn multisampling on, the tools behave normally.
The issue is originally mentioned in http://blenderartists.org/forum/showthread.php?390359-Box-and-circle-select-acting-strange-in-solid-drawing-mode
Added subscriber: @Stan_Pancakes
Added subscriber: @ideasman42
Do you have multi-sampling enabled in the nvidia-settings, but disabled in Blender?
I've seen this cause issues before.
If all MSAA settings are off from the driver side, and off from Blender's preferences, this should always work properly.
Note that Blender requests no MSAA, if the graphics card is giving us a multi-sampled buffer its unlikely we can fix this - unless theres some known workaround.
Added subscriber: @mont29
I have no overrides in nvidia-settings:
If the driver was giving a multi-sampled buffer, wouldn't the resulting image reflect that? Perhaps it's not clear in the video, but there's no AA in viewport.
Also, I should mention that I went and checked with both selection methods (Select and Occlusion Queries), it still behaves like that.
Another update: I tried replicating this behavior with 2.75a on the same system, but with that version selection tools operate normally.
Added subscribers: @MikeErwin, @brecht
Did you try playing with other settings, e.g. disabling that 'texture sharpening' option, or if you have some global 'performance vs. quality' slider, etc?
Otherwise, unless some of our OpenGL team dev (@brecht, @MikeErwin, etc.) can replicate the issue, I doubt we can do much. :/
Added subscriber: @ErickNyanduKabongo
I m having about the same problem in sculpt mode with mask lasso selection, I have win7 gtx 550ti and amd64 win 8, in both i have the same behavior. Hash
c292b4e
Check video https://youtu.be/iAlmA1neGFo
Neither 'Texture Sharpening' nor the OpenGL performance slider in nvidia-settings have an effect on this.
Here is with bones selection
https://youtu.be/7Er-Rcq3Z7A
@ideasman42, looking for suspicious commits between 2.75 and 2.76, I found this one:
53d73c51a7
. There is aglEnable(GL_MULTISAMPLE)
without a restore of the previous state, which seems wrong to me. I'm not sure if there actually exist conditions under which this will cause trouble, but maybe something like .blend thumbnail save.There were also lots of changes to ghost though, so it might be there too.
@Stan_Pancakes, does the problem happen after loading factory settings? It would be useful to know if perhaps some particular setting or addon is influencing this, besides the multisample setting.
@ErickNyanduKabongo, can you redo the problem in the original bug report? Can you redo the bugs you found in Blender 2.75, or do things work correctly there? It would be good to confirm if what you are seeing is actually the same bug.
@brecht, yes, it's factory settings. In fact, the video was recorded with factory settings as well. Sorry, I should have stated that more clearly to begin with.
@ErickNyanduKabongo, regarding lasso masking, AFAIK it always behaved this way: mask lasso always masks both front- and backfacing polygons, and with symmetry enabled, this results in what you show in your video.
The bone selection you're showing is also normal: selecting whole bone selects both its head and tail (and vice-versa). So, when you select the upper bone, its head is selected (which is also the head of middle bone). Then you select the lower bone, and its head gets selected (which is also the tail of middle bone). Thus, after selecting both of those bones, both the head and tail of middle bone are selected, so it's selected as well.
@brecht, now I couldn't redo the same behavior like op did. I remember I did reproduce something similar in my own old build and it is gone. The behavior comes randomly.
@Stan_Pancakes You are right i tried old Blender version, mask in sculpt mode and bone selection is like buggy normal behavior, my bad. :( One more thing that pushed me to show the video is the quick select and deselect that happen in my video about 23 sec, it is the same as photox showed in BA post#7. Probably it is an other problem here.
Another update: on my system, but with a much older driver (340.96) the behaviour is still the same.
Double checked and this commit wasn't in any of the 2.76 releases (timelines overlap, but wasn't merged into release branch).
The multi-sample state is stored/restored by
glPushAttrib(GL_ENABLE_BIT...)
, which is popped on un-binding, and will restore the multi-sample state.@ErickNyanduKabongo, Please submit a new bug report with a file that has problems selecting armatures - its quite likely these bugs are unrelated.
Not necessarily, I've found with nvidia drivers on Linux - Blender disables multi-sampling which shows without any visible FSAA, but still causes problems with selection.
@ideasman42, I've verified your suggestion. In all my test cases, I did Load Factory Settings in a Blender session that first loads my defaults (multisampling on, etc). I made a clean setup (removed startup.blend and userpref.blend), and the problem doesn't occur with it.
So, given the above, the actual reproduction route is:
This doesn't happen in wireframe view, or with Limit Selection to Visible disabled.
Tested with two GPUs: GTS450 and GTX560, and two driver versions: 340.96 and 355.11. In all combinations the selection behaviour is the same.
The problem did not occur in 2.75a because for that version my user preferences don't have multisampling enabled by default, I've just verified that it does reproduce the issue as per steps above.
However, just to make sure, I went further back and tested with 2.74, and on that version, I cannot reproduce the problem at all.
If this is indeed a Linux driver issue then this particular problem should be documented somewhere (since people use Load Factory Settings to verify issues, it's pretty bad if it actually introduces a problem). I could do this if someone would point me in the right direction. Wiki?
This issue was referenced by
6081f6c387
Ok, if that's the issue then it should be fixed now, thanks for tracking this down.
