OpenGL render with smoke and fire incorrect when using transparency #47639
Closed
opened 2016-03-01 10:20:51 +01:00 by Miika Puustinen (miikap) · 20 comments
Windows 8.1
I7-5820K 3.3GHz, 2x Asus GTX 960 4Gb, 32Gb RAM
Broken: 2.77 RC1 b594b25
Worked: 2.76 official
If fire rate is more than 1, fire doesn't render properly with opengl render.
How to reproduce:
  • Select default cube
  • Make quick efffect: quick smoke (fire option)
  • Change fire rate from the emitter to 10
  • Tick of smoke high resolution from domain settings (to get faster preview)
  • Make domain bigger by turning on adaptive domain and changing additional to 32 for example
  • sim/playback to frame 50
  • render opengl render / viewport render
  • compare to viewport
Example file:
http://www.pasteall.org/blend/40879
  • Miika P
Operating system and graphics card Windows 8.1 I7-5820K 3.3GHz, 2x Asus GTX 960 4Gb, 32Gb RAM **Blender Version** Broken: 2.77 RC1 b594b25 Worked: 2.76 official **Short description of error** If fire rate is more than 1, fire doesn't render properly with opengl render. How to reproduce: - Select default cube - Make quick efffect: quick smoke (fire option) - Change fire rate from the emitter to 10 - Tick of smoke high resolution from domain settings (to get faster preview) - Make domain bigger by turning on adaptive domain and changing additional to 32 for example - sim/playback to frame 50 - render opengl render / viewport render - compare to viewport Example file: http://www.pasteall.org/blend/40879 - Miika P
Author
Member
Author
Member
Added subscriber: @MiikaPuustinen
Added subscriber: @Sergey
I can't really reproduce the issue, but i'm on Linux. Some things which could clarify situation for us:
  • What are exact steps of reproducing the issue with attached .blend file?
  • Is it viewport only problem, or render also differs from 2.76 to 2.77?
  • Please attach screenshoot of your problem.
I can't really reproduce the issue, but i'm on Linux. Some things which could clarify situation for us: - What are exact steps of reproducing the issue with attached .blend file? - Is it viewport only problem, or render also differs from 2.76 to 2.77? - Please attach screenshoot of your problem.
Author
Member
  • Without the file follow the steps.
  • With attatched .blend file just sim to frame where there is lot of flames (50 or so). Take an opengl render.
2.76 gives same result in opengl render and in the viewport.
2.77 fire is transparent and weird colored. Higher the flame value, lower the opacity of the flame (see screenshot).
http://www.pasteall.org/pic/100012
- Without the file follow the steps. - With attatched .blend file just sim to frame where there is lot of flames (50 or so). Take an opengl render. 2.76 gives same result in opengl render and in the viewport. 2.77 fire is transparent and weird colored. Higher the flame value, lower the opacity of the flame (see screenshot). http://www.pasteall.org/pic/100012
Ah ok, got it now. Not sure why OpenGL will use transparent background now actually. Needs investigation.
Kevin, any ideas here?
Ah ok, got it now. Not sure why OpenGL will use transparent background now actually. Needs investigation. Kevin, any ideas here?
Member
Added subscriber: @MikeErwin
Member
Added subscriber: @kevindietrich
Member
@kevindietrich This is your area, right?
I checked out the commit before my rewrite of the smoke drawing and rendering either the default scene or a smoke sim also resulted in a transparent background, so chances are this is not related to volume rendering (or not my fault). Rendering fire alone is apparently broken after my change, so that one is on me.
This comment was removed by @kevindietrich
*This comment was removed by @kevindietrich*
Member
Added subscriber: @Blendify
Member
This is not only true for smoke but anything will render transparent unless show world background is enable. This is different then 2.76b where it works correctly.
Aaron Carlisle changed title from Smoke sim opengl render doesn't match to viewport drawing to OpenGL render is transparent unless "show background" is enabled 2016-03-05 03:05:43 +01:00
Author
Member
I think title was mistakenly changed to "OpenGL render is transparent unless "show background" is enabled".
This was the problem:
http://www.pasteall.org/pic/100187
Bottom image 2.77RC, top one 2.76.
I think title was mistakenly changed to "OpenGL render is transparent unless "show background" is enabled". This was the problem: http://www.pasteall.org/pic/100187 Bottom image 2.77RC, top one 2.76.
Brecht Van Lommel changed title from OpenGL render is transparent unless "show background" is enabled to OpenGL render with smoke and fire incorrect when using transparency 2016-03-05 13:27:11 +01:00
Added subscriber: @brecht
The shaders here changed a lot, previously it was drawing smoke and fire separately, with different OpenGL blend modes.
The tricky thing here is that we are rendering to a 0..1 clamped sRGB buffer with unpremultiplied alpha, where the correct thing to do would be to render to an unclamped linear premultiplied alpha buffer. Then you would just make fire purely emissive without affecting the alpha channel at all, but that doesn't work here.
The alpha channel in 2.76 is much too dense but perhaps that is required to make it work. I'm not sure yet what the solution is, maybe the shader needs to be split up again.
The shaders here changed a lot, previously it was drawing smoke and fire separately, with different OpenGL blend modes. The tricky thing here is that we are rendering to a 0..1 clamped sRGB buffer with unpremultiplied alpha, where the correct thing to do would be to render to an unclamped linear premultiplied alpha buffer. Then you would just make fire purely emissive without affecting the alpha channel at all, but that doesn't work here. The alpha channel in 2.76 is much too dense but perhaps that is required to make it work. I'm not sure yet what the solution is, maybe the shader needs to be split up again.
Kévin Dietrich was assigned by Sergey Sharybin 2016-07-27 11:27:46 +02:00
Kevin, did you have chance to have a look into fire issue?
No, I haven't had a chance yet to look into this more deeply, kinda forgot about that.
This issue was referenced by 116bab702e
This issue was referenced by 116bab702e009ce8043b976b4a9c4afa4c7ff5b0
7 Participants
Reference: blender/blender#47639
