Using template_list() with invoke_props_dialog() #47657
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#47657
Kubuntu 15.10
Nvidia GeForce 9600 GT (driver: 340.96)
Broken: 2.76b
Not reproducible in 2.77rc1 because of #47632.
An attempt to redraw property dialog that contains template_list() function crashes Blender:
Added subscriber: @AleksandrZinovev-2
Added subscribers: @JulianEisel, @ideasman42, @mont29
Problem is, ui_list depends on a valid region available in context, and looks like context from popup do not have any region.
@JulianEisel, @ideasman42, do you know whether this is expected behavior? I'd assume we should get the temp popup region here?
Adding current temp
ARegion
to context in draw code solves the issue, see e.g. this quick patch:P330: #47657
Although it's pretty annoying, afaik it's intended behavior. Not 100% sure but I think
CTX_wm_menu
can be used to avoid this.Yes indeed, falling back to
CTX_wm_menu
in caseCTX_wm_region
returns NULL works in this case… Seems a bit odd to me though. :/Would do the other way around, falling back to
CTX_wm_region
whenCTX_wm_menu
fails.UI_block_draw
does this.I wish I could help with this bug but unfortunately I don't know c/cpp.
I noticed that when blender redraws dialogs it uses empty context object (region is None, space_data is None, etc). That behavior could cause other issues for context sensitive dialogs. Is it possible to "remember" context object that was used in invoke method and use it for redrawing?
Will commit that CTX_wm_menu 'hack' for now, but note that uilist remains a bit flacky in such usage (e.g. resize handle does not work that nice), would consider that a TODO though. Popups are not really meant to support such advanced UI items...
This issue was referenced by blender/blender@bd335f13fe
