Layer weight gives incorrect result in GLSL Material mode #47670
Closed
opened 2016-03-02 22:18:07 +01:00 by Eelco Dolstra · 12 comments
NixOS Linux, kernel 3.18.26
GeForce GTX 970, driver 352.63
Broken: 2.77-rc1
Worked: 2.76b
Cycles layer weight node shows an incorrect result in Material mode in the viewport.
In 2.76, the attached file shows as follows:
While in 2.77-rc1 I get this:
See attached blend file in Material mode in the viewport.
bug.blend
A workaround is to connect the Normal input of the Layer weight node to the Normal output of a Geometry node. However, connecting to a image texture normal map gives wrong results.
Note: reverting commit 72dd1ba3fe ("Fix #47349: incorrect Cycles fresnel and layer weight with GLSL materials") fixes the problem for me. However, that does break the workaround described above (i.e. where the Normal output of the Geometry node is used).
**System Information** NixOS Linux, kernel 3.18.26 GeForce GTX 970, driver 352.63 **Blender Version** Broken: 2.77-rc1 Worked: 2.76b **Short description of error** Cycles layer weight node shows an incorrect result in Material mode in the viewport. In 2.76, the attached file shows as follows: ![good-2.76.png](https://archive.blender.org/developer/F286701/good-2.76.png) While in 2.77-rc1 I get this: ![bad-2.77.png](https://archive.blender.org/developer/F286703/bad-2.77.png) **Exact steps for others to reproduce the error** See attached blend file in Material mode in the viewport. [bug.blend](https://archive.blender.org/developer/F286705/bug.blend) A workaround is to connect the Normal input of the Layer weight node to the Normal output of a Geometry node. However, connecting to a image texture normal map gives wrong results. Note: reverting commit 72dd1ba3fe67206680ef3540b681d944e8bb4872 ("Fix #47349: incorrect Cycles fresnel and layer weight with GLSL materials") fixes the problem for me. However, that does break the workaround described above (i.e. where the Normal output of the Geometry node is used).
Author
Author
Added subscriber: @edolstra
#47716 was marked as duplicate of this issue
Added subscriber: @NikoLeopold
Brecht Van Lommel was assigned by Thomas Dinges 2016-03-03 22:34:16 +01:00
Brecht, can you please check? :)
Added subscriber: @cheleb
This issue was referenced by 002deb29cb
This issue was referenced by 002deb29cbc2fe1045189aef42bf61785c614cb8
Author
Thanks! However, it still gives an incorrect result when the layer weight has a Normal Map node as an input, e.g.:
In 2.76 the normal input had no effect in GLSL mode (i.e. the output looked like the first image above).
Thanks! However, it still gives an incorrect result when the layer weight has a Normal Map node as an input, e.g.: ![bad2.png](https://archive.blender.org/developer/F288649/bad2.png) In 2.76 the normal input had no effect in GLSL mode (i.e. the output looked like the first image above).
This issue was referenced by 6bfd88acd9
This issue was referenced by 6bfd88acd9498bb068bde7ab047a593254b96a88
Added subscribers: @kevindietrich, @snapai
6 Participants
Reference: blender/blender#47670
