Rigidbody constraint collision problem #47758
Closed
opened 2016-03-11 10:29:42 +01:00 by Martin Felke · 10 comments
Member
Linux Mint 17 64 bits, I7 2600, 16 GB RAM, Geforce GTX 580
Broken: 2.77 0bcbbb1
Worked: 2.76b
Rigidbodies do not collide even after their constraint is broken when "Disable Collisions" is active in Rigidbody Constraint Settings.
This setting is only supposed to suppress collisions between objects with intact constraints. Maybe there was a change / bug in recent bullet update (2.83 ?)
As workaround one could deactivate "Disable Collisions", but this leads to different simulation behavior.
Behavior in 2.76b:
Behavior in 2.77:
Open attached blend and just press Alt A. Notice how in 2.76 the cubes do not penetrate each other while they do in 2.77 (which is wrong)
bullet_constraint_collision_test.blend
**System Information** Linux Mint 17 64 bits, I7 2600, 16 GB RAM, Geforce GTX 580 **Blender Version** Broken: 2.77 0bcbbb1 Worked: 2.76b **Short description of error** Rigidbodies do not collide even after their constraint is broken when "Disable Collisions" is active in Rigidbody Constraint Settings. This setting is only supposed to suppress collisions between objects with intact constraints. Maybe there was a change / bug in recent bullet update (2.83 ?) As workaround one could deactivate "Disable Collisions", but this leads to different simulation behavior. Behavior in 2.76b: ![bullet_constraint_collision_test_276.png](https://archive.blender.org/developer/F289456/bullet_constraint_collision_test_276.png) Behavior in 2.77: ![bullet_constraint_collision_test_277.png](https://archive.blender.org/developer/F289458/bullet_constraint_collision_test_277.png) **Exact steps for others to reproduce the error** Open attached blend and just press Alt A. Notice how in 2.76 the cubes do not penetrate each other while they do in 2.77 (which is wrong) [bullet_constraint_collision_test.blend](https://archive.blender.org/developer/F289455/bullet_constraint_collision_test.blend)
Author
Member
Author
Member
Added subscriber: @scorpion81
Author
Member
Added subscriber: @erwin
Author
Member
Also mentioned this at the bullet github issue tracker:
https://github.com/bulletphysics/bullet3/issues/582
Also mentioned this at the bullet github issue tracker: https://github.com/bulletphysics/bullet3/issues/582
Member
Added subscriber: @LukasTonne
Added subscribers: @brecht, @Sergey
@brecht, guess this is caused by the Bullet update. Mind having a look here? :)
Brecht Van Lommel was assigned by Sergey Sharybin 2016-03-22 16:16:25 +01:00
This issue was referenced by e14324daa7
This issue was referenced by e14324daa72f21405b697d87c6d2d780873167b3
It seems this is a bug in Bullet, introduced here. The previous code would check if the constraint is enabled before disabling collisions, the new code no longer does that as far as I can tell.
https://github.com/bulletphysics/bullet3/issues/165
Reverted that change with a custom patch for now, hopefully it will be fixed in Bullet in the future.
It seems this is a bug in Bullet, introduced here. The previous code would check if the constraint is enabled before disabling collisions, the new code no longer does that as far as I can tell. https://github.com/bulletphysics/bullet3/issues/165 Reverted that change with a custom patch for now, hopefully it will be fixed in Bullet in the future.
5 Participants
Reference: blender/blender#47758
