Select next active does not work with some ngons #47967
6 Participants
Reference: blender/blender#47967
Windows 10,AMD 5450
Blender 2.77.Hash:
22a2853
Select next active tool doesn't work near ngons in multiple cases and blender give me "No single next item found".
Add a plane with an ngon in the middle and try to select some edges:
Added subscriber: @omar-1
Added subscriber: @sindra1961
I think that your usage is wrong.
You say that you chose plural edges, but plural vertices is chosen with the attached image.
It is necessary for the tool to choose at least two items.
And a result varies according to a turn to choose.
I think that it does not work definitely if you do not know how data are managed inside.
I'm sorry, translation was wrong.
Well,I tried using edges and it didn't work,then I tried using vertices and it didn't work too,thats where i took the screenshot.
Sorry for misunderstanding.
Added subscriber: @SatoshiDoita
It is because number of possible items is even.
and this tool requires number of branch is odd and those must be sortable by sharing faces.
So a temporary inserted face would solve the problem?
I think that you should check the below .py file if you want to know how it works.
2.77\scripts\startup\bl_operators\bmesh\find_adjacent.py
def find_next(ele_dst, ele_src)
This function picks up an items.
sorry, my bad english.
Select next active does not work with ngons.to Select next active does not work with some ngonsThis tool works with ngons. so it must be some certain ngon topologies that confuse it.
Added subscriber: @Sergey
Here's a test file: #47967.blend
This issue was referenced by
c3ed6010af
I tested it by a revised edition, but is this case this right?
untitled.blend
It was the result that I expected in the case of vertice/face select mode.
But edge select mode is ....
@sindra1961, tested untitled.blend, and as far as I can see results are OK as far as I can see.
