Smart UV Project - small faces packed into a single point #48086
5 Participants
Reference: blender/blender#48086
Windows 7 and 10, GeForce GTX 970
2.77a
Small faces are packed into a single point in a left bottom corner of uv space when using Smart UV Project. When the same object is scaled up the problem doesn't occur. The model was originally created in CAD program, and exported from 3ds max to fbx.
Select object "b". In edit mode press "u". Use Smart UV Project. Area weight 0 gives overlapping islands, 1 gives better results, but in both cases there are zero area islands (see picture): Object "a" is the same model but scaled up that doesn't produce the same error.
test blend file: smart_uv_unwrap_bug_2.77.blend
Added subscriber: @MarcinTwarowski
Added subscribers: @brecht, @mont29
You are probably hitting float precision limits here? CAD exports have really horrible geometries…
@brecht maybe you have better insight on possible causes of that issue?
Added subscriber: @ideasman42
@ideasman42 wrote this operator I think, I'm not familiar with this code. I don't think float precision limits are the issue here, it's not that extreme a difference in scale.
Selecting just those vertices in the corner and trying to use Smart UV project on those also gives me an error:
This is caused by fix for #31598... will see if there is some reasonable limit for small faces that works for both.
This issue was referenced by
4ee5ba41bb
