open .blend file will be crash with blender 2.77a #48176
Closed
opened 2016-04-17 09:24:42 +02:00 by Leroy · 7 comments
windows 7 sp1 64bit
Broken: blender 2.77a abf6f08
open the .blend file will be crash, I do not know what causes, and the .blend file is download from blendswap. I have tried on several computer with different windows system.
The file link : http://www.blendswap.com/blends/view/67739
Just open it with blender 2.77a, than blender will be crash, but sometimes can open it in normal, and sometimes switch layer will be crash too, I don't know who causes, but if you delete the ground object than save it, it's will be work fine.
Thanks
**System Information** windows 7 sp1 64bit **Blender Version** Broken: blender 2.77a abf6f08 Worked: (optional) open the .blend file will be crash, I do not know what causes, and the .blend file is download from blendswap. I have tried on several computer with different windows system. The file link : http://www.blendswap.com/blends/view/67739 **Exact steps for others to reproduce the error** Just open it with blender 2.77a, than blender will be crash, but sometimes can open it in normal, and sometimes switch layer will be crash too, I don't know who causes, but if you delete the ground object than save it, it's will be work fine. Thanks
Author
Author
Added subscriber: @Leroy-Xie
Added subscribers: @Sergey, @ideasman42
Sergey Sharybin was assigned by Campbell Barton 2016-04-17 21:55:56 +02:00
Confirmed, the issue is that 2+ shrinkwrap constraint are releasing the subsurf derived mesh, which frees temporary data.
However this happens without any locking, causing a double-free in own tests (target->release(target); at constraint.c:3526).
For now, if you want to use this file, you can run Blender with the -t 1 argument to disable multi-threading.
Assigning to @Sergey
Confirmed, the issue is that 2+ shrinkwrap constraint are releasing the subsurf derived mesh, which frees temporary data. However this happens without any locking, causing a double-free in own tests (`target->release(target);` at constraint.c:3526). For now, if you want to use this file, you can run Blender with the `-t 1` argument to disable multi-threading. Assigning to @Sergey
@ideasman42, i can't really reproduce the issue, so having some additional info would help.
But basically, from what i see. Shrinkwrap constraint only need DerivedMesh to construct BVHTree. BVHTree will create a copied of vert/loops/looptris arrays if those layers do not exist yet (meaning, no write to DM will happen). This means dm->release() is not really needed, and likely to be fully avoid, since currently it caused temporary layers to be freed. So in order to fix crash it should be enough to remove dm->release() call. This is in fact a correct thing to do.
However, temporary layers created in the DM by the DM users (not by DM itself) is a bug. This is because policy must be nobody can write to other's DM. So it's important to understand who writes to the DM. That's where some back traces form you might give some enlightenment.
So can you perhaps share some crash backtraces for further investigation?
@ideasman42, i can't really reproduce the issue, so having some additional info would help. But basically, from what i see. Shrinkwrap constraint only need DerivedMesh to construct BVHTree. BVHTree will create a copied of vert/loops/looptris arrays if those layers do not exist yet (meaning, no write to DM will happen). This means `dm->release()` is not really needed, and likely to be fully avoid, since currently it caused temporary layers to be freed. So in order to fix crash it should be enough to remove `dm->release()` call. This is in fact a correct thing to do. However, temporary layers created in the DM by the DM users (not by DM itself) is a bug. This is because policy must be `nobody can write to other's DM`. So it's important to understand who writes to the DM. That's where some back traces form you might give some enlightenment. So can you perhaps share some crash backtraces for further investigation?
This issue was referenced by 680b135ec1
This issue was referenced by 680b135ec1cf220c7ebd579b88bc5481fc379fc3
Reference: blender/blender#48176
