Armature in pose mode ignores selection popup (alt+RMB) #48203
Closed
opened 2016-04-20 04:15:51 +02:00 by Bloody Rain · 6 comments
Win7 x64 Premium 32gb, i5 6600, 2x970 GTX 2gb
2.77 abf6f08
When using the selection popup used to chose which object to select in case of overlaying objects will an armature in posemode always ignore this selection mode and be selected right away without the popup even showing up in the first place.
https://dl.dropboxusercontent.com/u/59546146/AltSelect.blend
This file contains a simple setup with an empty and an armature containing a single bone and both sitting at 0,0,0.
The armature is in posemode and every single time I attempt to get the selection popup by Alt+Rightclicking them to select the empty will the armature instead take the selection every single time. It also doesn't work for bones in an armature in pose mode in case these overlap, so I'd guess that armatures ignore Alt+Select completely.
If the armature is taken out of pose mode then Alt+RMB works for opening the popup and selecting an object, it's only not working if an armatures in posemode is in the pile.
**System Information** Win7 x64 Premium 32gb, i5 6600, 2x970 GTX 2gb **Blender Version** 2.77 abf6f08 **Short description of error** When using the selection popup used to chose which object to select in case of overlaying objects will an armature in posemode always ignore this selection mode and be selected right away without the popup even showing up in the first place. **Exact steps for others to reproduce the error** https://dl.dropboxusercontent.com/u/59546146/AltSelect.blend This file contains a simple setup with an empty and an armature containing a single bone and both sitting at 0,0,0. The armature is in posemode and every single time I attempt to get the selection popup by Alt+Rightclicking them to select the empty will the armature instead take the selection every single time. It also doesn't work for bones in an armature in pose mode in case these overlap, so I'd guess that armatures ignore Alt+Select completely. If the armature is taken out of pose mode then Alt+RMB works for opening the popup and selecting an object, it's only not working if an armatures in posemode is in the pile.
Author
Author
Added subscriber: @BloodyRain
Added subscriber: @FabienDevaux
Same on Archlinux, 2.77 abf6f08 16GB RAM / GTX 760
This issue was referenced by bd40ded9f6
This issue was referenced by bd40ded9f659e0bd34d4843b8c5882307274be82
Reference: blender/blender#48203
