SIGSEV in ccl::ImageManager::device_free_image #48377
Closed
opened 2016-05-08 19:00:09 +02:00 by Ralf Hölzemer · 5 comments
system-info.txt
Broken: f5930759a6 - sorry Brecht! :)
Worked: 68e856da03
Blender crashes when a Color Mix node has a float Texture connected to one input and nothing on the other input and the mix factor is set to the empty input.
This is an obscure one and it took me way too long to figure out.
Some preconditions which are required to trigger the bug: (AFAIKT)
  • There has to be an active 3dview with the vieport shading mode set to "Rendered"
  • The image that is connected to the Mix node has to be a float image
  • The other input of the Mix node must be unconnected
  • open mix_node_bug2.blend
  • set the 3dview shading mode to Rendered
  • slide the Mix node's factor up to 1
crash -> backtrace.txt
The crash doesn't happen when the image is a byte image
  • open the file again
  • connect the second image texture to the first input of the Mix node instead of the float one
The crash also doesn't happen when the second input is connected to a byte image
  • connect the second image texture to the second input of the Mix node
**System Information** [system-info.txt](https://archive.blender.org/developer/F309794/system-info.txt) **Blender Version** Broken: f5930759a6 - sorry Brecht! :) Worked: 68e856da03 **Short description of error** Blender crashes when a Color Mix node has a float Texture connected to one input and nothing on the other input and the mix factor is set to the empty input. This is an obscure one and it took me way too long to figure out. **Some preconditions which are required to trigger the bug: (AFAIKT)** - There has to be an active 3dview with the vieport shading mode set to "Rendered" - The image that is connected to the Mix node has to be a float image - The other input of the Mix node must be unconnected **Exact steps for others to reproduce the error** Based on a (as simple as possible) attached .blend file with minimum amount of steps - open [mix_node_bug2.blend](https://archive.blender.org/developer/F309796/mix_node_bug2.blend) - set the 3dview shading mode to Rendered - slide the Mix node's factor up to 1 crash -> [backtrace.txt](https://archive.blender.org/developer/F309797/backtrace.txt) The crash doesn't happen when the image is a byte image - open the file again - connect the second image texture to the **first input of the Mix node instead of the float one** - set the 3dview shading mode to Rendered - slide the Mix node's factor up to 1 The crash also doesn't happen when the second input is connected to a byte image - open the file again - connect the second image texture to the **second input of the Mix node** - set the 3dview shading mode to Rendered - slide the Mix node's factor up to 1
Author
Author
Added subscriber: @cheleb
This issue was referenced by e362b04c43
This issue was referenced by e362b04c43d23ccc4ec14e26d481c283705ef9cf
This issue was referenced by blender/cycles@daad318936
This issue was referenced by blender/cycles@daad31893647468d36b6c1ba5e8d5627e52bd75e
Reference: blender/blender#48377
