Missing Render Passes in Multilayer EXR #48466
Reference: blender/blender#48466
Win 7 Ultimate, GTX 780
Broken: 2.77
Missing Render Passes DIFFUSE DIRECT and DIFFUSE INDIRECT in Multilayer EXR
... rendered out and save through output node and imported as exr image
the rest 23 passes out of 25 works fine
see attached blend file MultiEXR_missing_passes.blend
Added subscriber: @zajooo
Added subscriber: @zeauro
ubuntu 14.04 64bits master
89df672
I confirm problem with attached.blend but I can't redo it from scratch.
Engine for rendering: Cycles Render
Properties/Render Layers/Passes/Enable Difuse: [Direct] [Indirect] [Color]
Node Editor / Compositing / - Use Nodes / - Backdrop
Add Output / File Output set file format to: OpenEXR Multilayer
+Add Input 4 times, for Alpha, Diffuse Direct, Diffuse Indirect and Diffuse Color and rename them
Connect the to coresponding outputs from Render Layer node to File Output node
Set path to render to
hit F12 to render
In Node editor add Input / Image
Load the rendered image from the path you have previously setted up
DIFFUSE DIRECT and DIFFUSE INDIRECT are missing
Cheers Jozef
Any news, any other confirms of the issue ?
Added subscriber: @mont29
Issue is not in saving actually, but in loading EXR multipass images. Blender tries to detect the pass types from their names (using pre-defined names of its own render result), and here any pass name starting with 'Diffuse' is detected as DIFFUSE pass (expects
DiffDir
,DiffInd
etc. for direct, indirect etc. diffuse passes). Since we do not support several passes of the same type…Fix incomming.
This issue was referenced by
6befc76265
just downloaded the daily build to take check it
now it works in therms of no missing passes
but it does not keeps the Layer naming from File Output
It is saved as "Diffuse Direct" and loaded as "DiffDir"
but it is hard coded as I have seen in the fix in render_result.c
anyway I am happy to see no missing passes :)
Thumb up guys, great job !
Cheers
Jozef
Eeeeeeh! no, absolutely not, you must be loading the wrong EXR file in your viewer node! This one must have been saved directly from a render or something - in any case, not from your file save node, or you would not have the 'combined' pass in it. ;)
My fault, INDEED WORKS LIKE IT SHOULD, I was reading the file from my Desktop not from my File output Temp directory.
Cheers ;)
