Color Mix "Add" mode is broken in Cycles #48587
Closed
opened 2016-06-04 03:30:16 +02:00 by bassam kurdali · 10 comments
Member
GNU/Linux 64bit (Intel CPU/nvidia GPU) / Fedora 23
Broken: 2.77 17fbce9 (git master)
Worked: 2.77a release
Using a Color Mix node with the first color being white and the second color black (zero on all channels) results in a Black output in "Add" mode even though 0 + 1 should be 1 not zero . my guess is that Add is doing a Mix by accident.
  • Download the File Attached bug.blend bug.blend
  • Open the file
  • set the viewport to rendered
  • observe the black color (it should be white)
**System Information** GNU/Linux 64bit (Intel CPU/nvidia GPU) / Fedora 23 **Blender Version** Broken: 2.77 17fbce9 (git master) Worked: 2.77a release **Short description of error** Using a Color Mix node with the first color being white and the second color black (zero on all channels) results in a Black output in "Add" mode even though 0 + 1 should be 1 not zero . my guess is that Add is doing a Mix by accident. **Exact steps for others to reproduce the error** - Download the File Attached bug.blend [bug.blend](https://archive.blender.org/developer/F315903/bug.blend) - Open the file - set the viewport to rendered - observe the black color (it should be white)
Author
Member
Author
Member
Added subscriber: @BassamKurdali
Added subscriber: @Ace_Dragon
In addition, from my own tests, the add mode for Color Mix seems to be broken only for the case when it gets fed a value of 1 (other values like 0.9 seem to work as intended).
In addition, from my own tests, the *add* mode for Color Mix seems to be broken only for the case when it gets fed a value of 1 (other values like 0.9 seem to work as intended).
Author
Member
that seems to be the case, at least in the example file. Well spotted (and thanks Thomas for adding Cycles project... I should have done so)
This issue was referenced by 234801c8dc
This issue was referenced by 234801c8dc42f0f24e6f90691451b462942ffe56
Author
Member
Thanks Dingto! confirming 'FIXED' both on the test .blend I uploaded and on the original tube files that exposed the bug in the first place. Great work!
This issue was referenced by blender/cycles@75436eacdc
This issue was referenced by blender/cycles@75436eacdc04ac9a97b66a91002642d847d3f084
Reference: blender/blender#48587
