Python: Modal operator's 'report' behaves differently when called from non-modal operator #48717
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
5 Participants
Reference: blender/blender-addons#48717
Broken: 2.77a and
Description of error
Calls to
self.report()
from the modal operator are not shown in the UI, when that modal operator is called from a non-modal operator. This makes it difficult to communicate with the user from long-running operators.Furthermore, there is a difference in console output:
Modal operator called from space-menu:
Modal operator called from non-modal operator:
Open the attached blend file and run its script: test_nonmodal_calling_modal.blend
Press SPACE in the 3d viewport (under the text editor) and choose 'Modal operator -- run me first'.
See a
self.report({'INFO'})
with decreasing counter appear four times, for counter=3, 2, 1, 0.Inspect the console output, and see that there are four log entries one second apart, and below that only one Info line from
with counter=0, which was printed after the modal operator was stopped.Press SPACE in the 3d viewport and choose 'Non-modal operator -- run me second'.
Press the 'OK' button or hit Enter.
See the
from the non-modal operator, but not from the modal operator it calls.Inspect the console output, and see that there are four log entries one second apart, and below that four Info lines from
with counter=3, 2, 1, 0, which were printed after the modal operator was stopped.Changed status to: 'Open'
Added subscriber: @dr.sybren
Added subscriber: @VukGardasevic
Modal operator behaves differently when called from non-modal operatorto Python: Modal operator's 'report' behaves differently when called from non-modal operatorAdded subscriber: @mont29
Tried to understand follow that report thing this afternoon, with not much luck… In fact, I do not understand why the report of the first, directly called modal op works, since afaict python creates own report when calling an op, with
RPT_OP_HOLD
, which is supposed to prevent its drawing in header bar (seewm_operator_reports
andwm_add_reports
)…Hopefully @ideasman42 will know better!
This issue was referenced by blender/blender@f1253f5d2b
Awesome! Thanks for the quick fix :)
