material remapping work properly only the first time #48740
Reference: blender/blender#48740
Win 7 x64
Broken:
2a69b09
Remapping an object's material work the first time, but switching back to original one won't work. It may change other object's material by the way.
red.blend
green.blend
Download both files in one directory. Open green.blend and remap red material (linked) in outliner to green material. Red object becomes green, correct.
Now remap again this material to green, nothing happens. Sometime, the green object becomes red, but the red object will stay green forever.
Added subscriber: @bliblubli
Trying to solve the problem with undo (instead of remapping again the other way) creates a lot of users (18 in my case) and make the object black without any material.
Added subscriber: @mont29
Hrrrmmm… remapping linked data… not even sure I checked that use case! :P
Yeah, this should not be allowed, you cannot remap linked data usages that way, it's calling for problems (linked data is assumed 'frozen' and non-editable). Will add checks in code to prevent this to happen!
It's one solution. Maybe a better one for user would be to ask if he wants to edit the original file. Then changes could be saved to original data. Now that you have implemented a way to save specific datablocks to another .blend in the API, it should be doable?
Would rather not do that - at all. Would make library handling even more complicated (and believe me, it’s already rather hairy code).
Library editing should be featured separately, as an addon e.g., which would simply launch another blender session with relevant library file etc.
This issue was referenced by
e2c7ee7733
Thanks for the fix. Problem with addons is that they are most of the time not so well maintained/programmed on the long run. They also tend to become slow when managing big amount of datas. And I'm pretty sure we will arrive to 3-4 addons doing the same job, none of them being fully featured
Trying to implement a custom addon as you said, I used the new operator to write datablock to an external .blend. It seems to erase everything else, to only keep the saved datablock. Am I doing something wrong or are you going to add the possibility to append later?
Regards
