Custom icon is not drawn on header / addons prefs panel #48813
5 Participants
Reference: blender/blender#48813
Kubuntu 16.04, GeForce 8800 GTS 512
Broken: 2.77a and
8bb69b6157
When drawing a button or label with a custom icon on a header or addons panel, the icon isn't shown. Only after forcing a redraw (for example by moving the mouse over the UI element) the icon gets drawn.
If you go to the properties editor, objects tab, the script also registers a button there, in a custom panel. You can also see that it is drawn without the icon first, but is redrawn when the icon is loaded. My bet is that this redraw trigger doesn't happen for other areas.
Added subscriber: @dr.sybren
Added subscribers: @mont29, @Sergey
@mont29, is it something in your area?
Added subscriber: @ideasman42
Problem is that those 'custom icons from file' are asynchronously deferred loaded, using 'generic' icon generation job, which generates NC_MATERIAL notifications. Replacing those with NC_WINDOW does fix the issue, question is, do we accept that kind of 'redraw everything' message from icon generation? @ideasman42, what do you think?
@mont29, right, we can always add global redraw flags to workaround these issues. In this case I don't have a strong opinion,
though IMHO it's quite weak - the more add-ons use generated icons, the more we will redraw everything when they update.
I think we need a more flexible notification system which doesn't depend on hard coded values (making assumptions about whats shown in a region).
Currently a Python script may show any information in the UI, its totally hit-and-miss that the UI is refreshed when they're changed.
We could have design task for this (if someone has time to develop it...) would suggest moving to a publish/subscribe pattern for the notifier system where...
How fine-grained we need to be can be chosen later... per-property is possible but overkill. (probably ID & RNA-type is enough).
This way using dynamically generated icons is just a matter of asking to listen for changes to icons - a different kind of listener.
This allows for Python scripts to be able to register to be notified on changes too.
For the 3D-view for eg, it probably doesn't make sense to inspect whats drawn and listen to changes in each object's ID. It could just register a listener for changes to data-types (material, object-object data).
So something similar to the existing system could be done where needed.
While notifier is a weak solution it is the only one for now. So either we go this way or consider this a TODO.
Since for now we don't have have much addons who uses this function think it's acceptable to just use notifiers.
Yes, agree, for now notifier will do the work.
@ideasman42 your idea sounds nice, imho at this point should be part of the bigger 'workflow' 2.8 topic (as part of custom editors, which will require that kind of thing anyway)…
This issue was referenced by
f3f10e4515
Thanks guys!
