Memory leak on Blender Exit (possibly related to mixing BI and Cycles nodes and material data ) #48829
Closed
opened 2016-07-11 15:41:43 +02:00 by Vuk Gardašević · 4 comments
Amd X3 455, R7 360
Tested on:
Windows 7, blender versions: 4b0aeaf, 2.70a, a6ca8a1
Linux:
Ubuntu 16.04, blender version: 2b485e2
Arch Antergos, blender versions: 9d5661c, 47c47c7
After running a script that calls a prop search related to material data, blender reports GPU_link memory leaks on exit (with the -d parameter)
Example console/terminal output:
console_print.txt
Run blender with -d --factory-startup parameters, open the blend file attached > run script > search for simple object operator > change material from the prop search dropdown list> OK > Exit Blender.
The leak also seems to be triggered by just selecting the other material in the properties.
The attached file contains one cycles and one blender internal simple material and the script.
test_mem_leak_simple_op.blend
**System Information** Amd X3 455, R7 360 Tested on: **Windows 7**, blender versions: 4b0aeaf, 2.70a, a6ca8a1 **Linux:** Ubuntu 16.04, blender version: 2b485e2 Arch Antergos, blender versions: 9d5661c, 47c47c7 **Short description of error** After running a script that calls a prop search related to material data, blender reports GPU_link memory leaks on exit (with the -d parameter) Example console/terminal output: [console_print.txt](https://archive.blender.org/developer/F321549/console_print.txt) **Exact steps for others to reproduce the error** Run blender with -d --factory-startup parameters, open the blend file attached > run script > search for simple object operator > change material from the prop search dropdown list> OK > Exit Blender. The leak also seems to be triggered by just selecting the other material in the properties. The attached file contains one cycles and one blender internal simple material and the script. [test_mem_leak_simple_op.blend](https://archive.blender.org/developer/F321553/test_mem_leak_simple_op.blend)
Author
Member
Author
Member
Added subscriber: @VukGardasevic
This issue was referenced by 5f95ffe350
This issue was referenced by 5f95ffe35034120189340cd413f24979da92109e
Reference: blender/blender#48829
