Segfault when switching brushes while renaming another brush #49023
Reference: blender/blender#49023
Windows 64-bit, msvc2013
Broken:
357480f8c3
At this point, it sometimes crashes, and sometimes doesn't.
Added subscriber: @JoshuaLeung
@antoniov: Could you take a look to figure out what's going on here? It might be something subtle going wrong with the RNA set functions for the brush names.
I cannot reproduce (I'm running Windows 10 64bits) the error.
@JoshuaLeung The RNA code is very simple in RNA_scene.c, so I don't think this is the problem.
@JoshuaLeung After a lot of test, I got this:
backtrace
33: BLI_system_backtrace - 0xCF94EC0
32: sig_handle_crash_backtrace - 0xBC5FCB0
31: sig_handle_crash - 0xBC5FD00
30: windows_exception_handler - 0xBC5FF80
29: UnhandledExceptionFilter - 0x6AFF7C70
28: memset - 0x6E51B900
27: _C_specific_handler - 0x6E505A90
26: _chkstk - 0x6E519A00
25: RtlImageNtHeaderEx - 0x6E4A4B30
24: KiUserExceptionDispatcher - 0x6E518BD0
23: strcmp - 0x10365B00
22: uniquename_find_dupe - 0xCF9CFC0
21: uniquename_unique_check - 0xCF9D060
20: BLI_uniquename_cb - 0xCF9ACD0
19: BLI_uniquename - 0xCF9ABD0
18: rna_GPencilBrush_name_set - 0xCCB56D0
17: GPencilBrush_name_set - 0xCCC3950
16: RNA_property_string_set - 0xCC65060
15: ui_but_string_set - 0xBF93420
14: ui_apply_but_TEX - 0xBFB8840
13: ui_apply_but - 0xBFBAF90
12: button_activate_exit - 0xBFB68F0
11: ui_handle_button_event - 0xBFCEC70
10: ui_handler_region_menu - 0xBFB6DF0
9: wm_handler_ui_call - 0xBC7AC80
8: wm_handlers_do_intern - 0xBC7DAF0
7: wm_handlers_do - 0xBC7E170
6: wm_event_do_handlers - 0xBC787C0
5: WM_main - 0xBC609E0
4: main - 0xBC59580
3: __tmainCRTStartup - 0x1036B900
2: mainCRTStartup - 0x1036BB20
1: BaseThreadInitThunk - 0x6D6480E0
0: RtlUserThreadStart - 0x6E4CC580
You can see the problem is in unique name function
The RNA set of brushes name is equal to layers name, so I don't see why we get this error.
Added subscriber: @mont29
I can easily reproduce on linux with debug build + asan, will investigate (simpler to check when you can reproduce 100% of time ;) ).
This issue was referenced by
df7be61438
@mont29 I'm new to RNA code, so I'm not sure, but there are more lines in the same file using the same code that you fixed (51, 516, 524, 534, ...).
Is it necessary to replace all of them?
I previous message I mean, similar code not equal. It is not clear for me the use of ptr->data yet :-)
@antoniov I did quick check while fixing, and no, those do not need same change.
Reason is,
rna_GPencil_active_brush_xxx
andrna_GPencilBrush_index_xxx
are callbacks of properties of an RNA struct definingRNA_def_struct_sdna(srna, "ToolSettings");
, which means they'll get aToolSettings
asptr->data
.On the other hand,
is callback of a property of an RNA struct definingRNA_def_struct_sdna(srna, "bGPDbrush");
, so it’ll get abGPDbrush
asptr->data
.In later case, you can luckily find 'parent' struct pointer from ID owner (Scene here), which is stored in
ptr->id.data
.Note that the code was pretty obviously broken though, same pointer being assigned as both toolsettings and gpdbrush… ;)
PS: just realized names of ``rna_GPencil_active_brush_xxx
and
rna_GPencilBrush_index_xxx` are 'wrong' (misleading), will fix that.Thnks for the explanation. After reading your comments I see the error was obvious.
Also, noted a
[+ reason/effect of using higher values of this property]
in tooltip of pen_smooth_steps, this looks like TODO note more than understandable tip to me? ;)
