Vertex Paint... not painting in the ViewPort #49220
Closed
opened 2016-09-01 13:34:31 +02:00 by Luca Crisi · 23 comments
Vertex Paint... is not painting in the ViewPort
OS: Windows 8.1 64 bit
GPU: nVidia GT740M
Not working Blender Version: 2.77a
Working Blender Version: 2.75
Said that i unwrapped the object and subdivided it a lot, when I try to vertex paint (using the draw brush) it in any color, nothing is painted.
But, the default "Col" Vertex Color group is being correctly created in the Object Data panel.
Possibly, the group contains the stroke info, but it's simply not drawn onto the mesh at paint time?
Vertex Paint... is not painting in the ViewPort OS: Windows 8.1 64 bit GPU: nVidia GT740M Not working Blender Version: 2.77a Working Blender Version: 2.75 Said that i unwrapped the object and subdivided it a lot, when I try to vertex paint (using the draw brush) it in any color, nothing is painted. But, the default "Col" Vertex Color group is being correctly created in the Object Data panel. Possibly, the group contains the stroke info, but it's simply not drawn onto the mesh at paint time?
Author
Author
Added subscriber: @BugFinder
#49221 was marked as duplicate of this issue
Added subscriber: @Sergey
Please don't use regressions project unless the thing worked in latest stable release. This project is used to indicate whether we've got show stoppers for the upcoming release.
As for the bug itself i can't reproduce it. Several things:
Please don't use regressions project unless the thing worked in latest stable release. This project is used to indicate whether we've got show stoppers for the upcoming release. As for the bug itself i can't reproduce it. Several things: - Test if 2.78 testbuild2 - [x] works for you. - Test if latest buildbot build works for you. - Provide exact steps with .blend file included which indicates the problem. - [x] http://download.blender.org/release/Blender2.78/
Author
Added the duplicate because I erroneously reported this bug the first time as REGRESSION.
I will not install a NOT OFFICIAL release:
There are already enough bugs in the official ones!
Steps to reproduce the bug (do you really need a .blend file for this?):
  • Unwrap an object and subdivided it a lot
  • Try to vertex paint (using the draw brush) it in any color: nothing is painted.
The default "Col" Vertex Color group is being created in the Object Data panel...
Without the color data, of course.
Added the duplicate because I erroneously reported this bug the first time as REGRESSION. I will not install a NOT OFFICIAL release: There are already enough bugs in the official ones! Steps to reproduce the bug (do you really need a .blend file for this?): * Unwrap an object and subdivided it a lot * Try to vertex paint (using the draw brush) it in any color: nothing is painted. The default "Col" Vertex Color group is being created in the Object Data panel... Without the color data, of course.
There is no need to install anything, you can download. zip archive, unpack it to any location, perform required tests and then remove the testbuild once you're done. This is the only way we can know if something is still affecting upcoming releases or not.
I did exact same steps on a default cude and did not see any issues. There are lots of various settings in blender and the only reliable way to know if something is not caused by specific combinations of those settings is to provide .blend file.
Also, are there any errors printed to the console when you're painting?
There is no need to install anything, you can download. zip archive, unpack it to any location, perform required tests and then remove the testbuild once you're done. This is the only way we can know if something is still affecting upcoming releases or not. I did exact same steps on a default cude and did not see any issues. There are lots of various settings in blender and the only reliable way to know if something is not caused by specific combinations of those settings is to provide .blend file. Also, are there any errors printed to the console when you're painting?
Author
It is supposed to be a red perimeter (or circumference) around the island mesh, since I vertex painted it all around it.
Instead, there is NOTHING.
And, yes, all the normals are facing UP
![Vertex NOT Paint.png](https://archive.blender.org/developer/F349682/Vertex_NOT_Paint.png) It is supposed to be a red perimeter (or circumference) around the island mesh, since I vertex painted it all around it. Instead, there is NOTHING. And, yes, all the normals are facing UP
Author
Test File:
There should be a red paint on that RoundCube
But there isn't
Vertex NOT Paint 02.blend
Test File: There should be a red paint on that RoundCube But there isn't ![Vertex NOT Paint 02.png](https://archive.blender.org/developer/F349685/Vertex_NOT_Paint_02.png) [Vertex NOT Paint 02.blend](https://archive.blender.org/developer/F349684/Vertex_NOT_Paint_02.blend)
Author
And... no. TestBuild 2 FAILED: Same result
And... no. TestBuild 2 **FAILED**: Same result
One more question from my side: are you painting with tablet or a mouse?
Author
Just a simple mouse...
Shouldn't it work?
Just a simple mouse... Shouldn't it work?
Well, it should. Just troubleshooting route depends on whether it's a tablet or mouse.
What about errors in the console? Did you check for those?
Well, it should. Just troubleshooting route depends on whether it's a tablet or mouse. What about errors in the console? Did you check for those?
Author
No... How do I do that?
Author
Or maybe there's something hidden in my preference settings which prevent the correct behaviour...
I'd be not very surprised to learn that:
Some months ago I discovered with the help of a Developer, here, that a setting of mine was preventing the Scripts from automatically running.
And it turned ot to be a bug only present in the Windows version of Blender.
Or maybe there's something hidden in my preference settings which prevent the correct behaviour... I'd be not very surprised to learn that: Some months ago I discovered with the help of a Developer, here, that a setting of mine was preventing the Scripts from automatically running. And it turned ot to be a bug only present in the Windows version of Blender.
Author
By the way... I posted another (completely different) bug.
Nearly at the same time of this one.
But no one seems to care about.
It's a bug in the File Save Screen not respecting the UI settings.
By the way... I posted **another** (completely different) bug. Nearly at the same time of this one. But no one seems to care about. It's a bug in the File Save Screen not respecting the UI settings.
Author
Just found a WORKAROUND: Just remove Use OpenSubDiv from the SubSurf Modifier.
Hope it helps someone else facing the same issue.
Just found a **WORKAROUND**: Just remove `Use OpenSubDiv` from the SubSurf Modifier. Hope it helps someone else facing the same issue.
Sergey Sharybin self-assigned this 2016-09-02 12:59:23 +02:00
Ah, that's a good thing. Had OSD device set to None in the preferences, so that's why it worked for me.
Ok, now can see the issue and will try to solve!
Ah, that's a good thing. Had OSD device set to None in the preferences, so that's why it worked for me. Ok, now can see the issue and will try to solve!
Author
Thank you, dear!
Thank you, dear!
This issue was referenced by 062732905a
This issue was referenced by 062732905ae52855d26884378de029e49bc68fec
Have a fix for the issue, will be committed once the Git is open again after RC1 builds are all ready.
Author
Wow! that's FAST!!
This is what I call EFFICIENCY!
Thank you!
Wow! that's FAST!! This is what I call EFFICIENCY! Thank you!
Reference: blender/blender#49220
