event.type=NONE if shift is pressed ( for MINUS and SEMI_COLON ) #49314
Reference: blender/blender#49314
Ubuntu 16.04.1 LTS / Nvidia 210
Broken: 2.78
7e7a9d1
Worked: 2.77
Mappings to certain keys do not work because the event.type is NONE instead of the expected value.
MINUS and SEMI_COLON, namely.
testkeypressvalue.blend
In the attached blend is a text file with the contents:
Having blender opened from a terminal or with the console open to see printed output, run the script and then with the mouse in the viewport, execute the operator 'Test Keypress Value' from the spacebar menu.
press and observe what the - and ; do with and without the shift key pressed. I am getting NONE for the type of event instead of MINUS or SEMI_COLON, respectively, whenever shift is pressed.
I haven't had time to test this on all possible key combinations but perhaps there are other affected keys as well.
thanks
Added subscriber: @bpygrams
Added subscriber: @mont29
Yeah… thanks for the investigation, this is due to
16cb939163
, will merge with other similar report below, and rework this… thing one more time.Closed as duplicate of #49303
This issue was referenced by
037df2aaa6
Changed status from 'Duplicate' to: 'Resolved'
